HELP, misfiring
Old Apr 20, 2019 | 09:52 PM
Michael Zosa's Avatar
Michael Zosa
Default HELP, misfiring
Hello all, I have pulled all of my spark plugs today and 5 of the 6 had this brown type of wear on them. The cylinders for those 5 also had carbon buildup in them, although my new build only has 100 miles on it. The 6th spark plug has little signs of wear however, and this cylinder hole has no buildup and i can still see the shine/reflectiveness on the cylinder head through the sparkplug hole.
Picture 1 is how 5 of the 6 look, pic 2 is the one with little wear. These are also new spark plugs aswell. I know I should get a tune and i'm not driving the car till then, but these signs show me that the misfire is caused by something else... I also do not misfire if I'm going over 70mph. Also have the O2 sensor codes for p0037 and p0057, and bank 1 vtc code p1111
Build :
11:1 Wiseco pistons, heads ported, valve job
FBO
NO TUNE
Old Apr 20, 2019 | 09:53 PM
Michael Zosa
Some of my friends were saying this is the result of a clogged injector on the cylinder with no wear, any insight on my situation? Thanks all.
Old Apr 20, 2019 | 11:12 PM
bealljk's Avatar
bealljk
Are you 10,000% sure you hooked #4 and #6 coils up correctly?
and then go get tuned ... you're jeopardizing your build by running un-tuned
Old Apr 21, 2019 | 12:01 PM
Michael Zosa
Yes I am sure, it is cylinder #3 (passenger side, middle cylinder) that is completely clean with no wear, which makes me think either the spark there is wrong or the injector is clogged ( due to the car sitting for 11 months). And thank you, I do not drive it anymore anyways till I fix this and get a tune.
Warku
Dec 15, 2012 08:06 AM
eez
Oct 5, 2007 03:50 PM
LiNks
Jan 13, 2006 04:51 PM
sentry65
Jan 14, 2005 08:51 PM
cquence 350 [Z]
Nov 12, 2004 01:53 PM
