HR engine to DE chasis and trans swap
The issue here is that most states/counties require emissions control and a standalone will instantly fail emissions.
start rant...
I giggle when where people want to put a HR / VHR into a DE chassis...
A. no gives a **** ... No one cares that you put a 2008-2015 nissan engine in a 2004 nissan chassis...people care if you LS-swapped or JZ-swapped
B. no significant power gains (keyword 'significant' - save your tweets, 40hp gain is not significant ... if 40hp is a significant gain in your world youre a small fish in a small pond) between a DE and an HR/VHR
C. Arguable more expensive and less options to power-mod a HR / VHR as compared to a DE. Some will argue...nfg
I laugh at HR guys that are proud of their 310hp FBO/tuned 350z - I make 310hp ... right around 3100rpm
end rant...
start rant...
end rant...
start rant...
I laugh at HR guys that are proud of their 310hp FBO/tuned 350z - I make 310hp ... right around 2300rpm
end rant...
start rant...
end rant...
start rant...
end rant...
start rant...
end rant...
Bro these guys been talking so much Im just here to ask for help on this swap I guess that one guy is jealous cause he has a de??? Lol thanks for the info btw
We were trying to save you time and money. Its not a direct bolt in swap and you won't gain much over the DE.
From a 2 second search, you need HR trans, steering rack, starter, and Haltech. The wiring harnesses and even the computers are completely different.
No one does this, because its not worth it. Just doing it "for fun" or not makes no difference. Also, its not fun throwing a bunch of money at a car to basically end up with the same thing you started with. You have an HR engine so I get why your inclined, but you can literally buy a 07 or 08 car for the same price as the swap will cost.
Dude I have an 350z with an hr but its auto im just swapping the engine into a de chasis that is manual so I wont have to do a custom shifter or clutch pedal I will also swap the auto to manual It has the 5at cpu and harness I heard its just minor wire work like switching some cables around in the harness All I will need is a 6 speed hr trans cause you cant use the 6 speed due to diffrent bell housings
This is why we rag on you... You ask for advice, advice is given and you respond with, "you're advice is s***". Even if you include the fact that you already have an HR engine and would need to buy an LS, the LS swap is cheaper and gives you 400HP to start with. It really is a no-brainer. We're telling you, there's a door right there and you're choosing to instead throw your body at the wall until you break through.
BTW, you'll also need a front subframe, or a tall cowl hood as the HR motor is much taller. The HR subframe mounts the engine lower than the DE subframe.
good - see yourself to the door
wait! That was rude ...
please hang around and start a build thread so you can showcase your automotive skills - I’m 10,000% serious...start a thread, upload pictures, and document your build. I’m interested to see this take shape.
THIS WILL STOP NOW!
Friend of mine asked me why I don't post as much as before. This thread is one reason why.
Here's the thing.... people come on here with all sorts of attitudes. The same monosyllabic tones and one sentence "requests for information" that go nowhere and then they get all sulky when people point out why they can't really answer or they don't like the answers they're getting.
Thought about just dropping out of this place but saw some questions that actually made sense and were thought out and researched. And then I see this thread and the defensive posturing to people who tried to help. Obviously not to the OP's liking I guess. Definitely rethinking my decision again.
Anyways, if this goes on any further, well, been awhile since anyone got banned here (Mostly because no one really cares what's on here anymore.)
I'd encourage it. These forums are simple and last for years. Give specifics and maybe even pictures along with a searchable title and you're helping the lurkers that dont want to cause any trouble.
LOL, well there won't be any pix unless you guys want to see my car getting loaded onto flatbed before they towed it away. The shop said they wouldn't remove the old TCM to actually show me the broken sections and suggested it'd be easier to replace my existing transmission [123k] with a slightly less used one [50k] with all parts included instead of me just purchasing a replacement TCM.
Back on topic, there seems to be a bit of a misunderstanding in this thread as to advice ie the financial aspect of a swap and the mechanics of said swap, two separate questions. Perhaps OP's should make it clear which aspect they would like advice on. It's understandable why someone would get peed off when they think financial aspect advice is what the OP wants.
My 33 is a circuit race car, AKA money pit, with a six 50mm throttle body DE so if it blows I'd want to keep it all Nissan with a VHR if possible. Another reason not to go LS is that would push more weight forward when a stock 33 is already front heavy. We all have our own priorities and requirements so there is 'no one size fits all' when it come to engine swaps. Given the above i'm interested in a VHR swap just in case.
EDIT The alternative for me would be to stay with a built DE, an ultimate DE if there is such an animal. More revs please
Jdm.350z
Mar 12, 2019 08:49 PM
ace32x
Oct 24, 2012 02:30 PM
