Windows, Door locks, and Mirrors not working
Old May 27, 2019 | 01:53 PM
KSwonger's Avatar
KSwonger
Default Windows, Door locks, and Mirrors not working
So I did the mod to install speaker wire into the doors by taking out the molex connector on the door, putting a hole through it, and running wire through the loom. I made sure of the pins being straight and nothing bent, I even did it twice on both sides and everything was fine. I got the passenger window to go down at one point but it doesnt want to come up. The doors lock/unlock with the key perfectly, as well as the trunk release. Im really stuck as to what to do right now...
Old May 27, 2019 | 02:30 PM
travlee's Avatar
travlee
Master
Check the window lock out button on driver side switch panel
Old May 27, 2019 | 02:47 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Even EXPERT EXPERIENCED wrenches have been known to get sucked in with that one. ^^^
Yep, happened to someone I know. 🤡
Old May 27, 2019 | 03:13 PM
KSwonger's Avatar
KSwonger
Nope didn’t change anything. I fear it’s the connectors but I made sure no pins were bent. When I put the connectors back together, they went together really smooth, like I had no slack in my speaker wire, and they connected perfectly so I don’t get it. I’m honestly just lost and defeated at the moment. Have a perfect 350z with a awesome sound system just sitting in the garage because a window is stuck down.
Old May 28, 2019 | 03:35 PM
KSwonger's Avatar
KSwonger
Update : Had a pin that was barely off center and turned a little bit. Straightened it out and everything works flawlessly now!
Old Jan 4, 2020 | 02:55 PM
Vince Gould's Avatar
Vince Gould
Default argh
what pin? What connector? I have the same problem.
jdub1234
Jan 5, 2020 06:59 AM
Axelrod
Nov 22, 2016 12:40 PM
SirSpeedyZ
Jun 29, 2014 01:09 PM
schrods
Apr 26, 2009 01:41 AM
