Oil foamy when doing oil change??
Old Nov 25, 2019 | 01:41 PM
Brian_z33's Avatar
Brian_z33
Default Oil foamy when doing oil change??
Hey guys, its about that mark where I do my oil change. Im using AmazonBasics full synthetic 5w-30 with K&N oil filter. Upon draining my oil, i noticed its foamy when draining from both plug and filter. Dipstick showed no foam and neither did fill cap. Is this something to be alarmed of? I have never had this issue and haven't experienced anything different in the way my Z runs. Its also taking a while to fully drain. Its been almost 10 mins and still keeps slowly draining.
Old Nov 25, 2019 | 02:10 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Hmmm- that is strange. I've never seen that kind of foamy oil discharge on any of my Zs. How many miles did you run on this change? What kind of oil are you using to do the change this time?
Old Nov 25, 2019 | 02:27 PM
Brian_z33's Avatar
Brian_z33
I ran it for about 5000+
Figured it was synthetic so it could last a bit longer. I finished my oil change and struggling to get an accurate reading. I dont want to overfill. Currently, car has been idling close to 10 mins and gauge reads exactly 30 psi. Is that normal? When revving it, it goes 100+ psi. Im using 5w-30 again for oil change
Old Nov 25, 2019 | 02:30 PM
Brian_z33's Avatar
Brian_z33
I heard foaminess can happen when you overfill and now im paranoid I overfilled because I cant get an accurate reading. I filled it with maybe 4.5-4.7 quarts of oil (i say this because the amazon gallon doesnt have measurement)
I let the car drain for about 10 mins, it still kept coming out very slowly so I just put the plug back on and continued.
This was the best photo I can take. Im going to let it sit for a bit and try to get another reading.
Old Nov 25, 2019 | 02:34 PM
travlee's Avatar
travlee
Master
Why would you use Amazon oil?
Old Nov 25, 2019 | 02:41 PM
Brian_z33's Avatar
Brian_z33
Whats wrong with Amazon oil? I have heard nothing but great reviews
Old Nov 25, 2019 | 02:48 PM
dkmura's Avatar
dkmura
Never seen a UOA of Amazon synthetic in a VQ35DE or HR. There's a great thread with UOA results from different oils being used in a VQ, but nothing for Amazon. You could be the first. As far as checking your dipstick, wait overnight and check the level BEFORE starting the engine.
Old Nov 25, 2019 | 02:55 PM
travlee's Avatar
travlee
Master
By amazon cheap asses........
Old Nov 25, 2019 | 03:03 PM
Brian_z33's Avatar
Brian_z33
Never seen a UOA of Amazon synthetic in a VQ34DE or HR. There's a great thread with UOA results from different oils being used in a VQ, but nothing for Amazon. You could be the first. As far as checking your dipstick, wait overnight and check the level BEFORE starting the engine.
Im not understanding, I could be the first...for this to happen? And I will def check again in the morning. However im making a 2 hr drive tomorrow after school and I just want to be safe im good on oil level
Brian_z33's Avatar
Brian_z33
Its not a matter of being a cheap *** lol. Money is not an issue. My dad just happened to buy in bulk and thats what we had so I used it
Old Nov 25, 2019 | 03:19 PM
travlee's Avatar
travlee
Master
Uh huh......(heavy sarcasm)
Old Nov 25, 2019 | 03:23 PM
rustyschopshop's Avatar
rustyschopshop
a quite a few years ago my father inlaw had the oil changed on our rogue someplace and they used Kendall. Did the same crap. Normally use moble1 and never had this issue since. 1st oil change after the kendall the oil was extremely nasty. Took 3 full mobile changes before it was back to complete normal.
Old Nov 25, 2019 | 03:27 PM
813_350Z's Avatar
813_350Z
It's possible you overfilled it. I made this mistake one time and promptly corrected it. You may also have some contamination in there from another source.
I'd recommend not using that oil again and use something such as Mobile 1. If it does it with the M1 then you may have an underlying reason for it that needs to be addressed. If it doesn't then that oil was just garbage and needs to be disposed of.
Just because it's lying around doesn't mean you should use it. Hi-Point makes pistols, but I wouldn't buy one.
Stick with quality oil. it may save you from costly repairs in the future
Old Nov 25, 2019 | 03:44 PM
Brian_z33's Avatar
Brian_z33
Gotcha. Atleqst for right now. I currently did my change with more Amazon oil. I don't mind ordering some M1 and redoing my oil change. With that being said, I put about 4.5 qts of oil...Im going to try and get a reading but I am having trouble trying to ACCURATELY get one
Old Nov 25, 2019 | 03:46 PM
Brian_z33's Avatar
Brian_z33
Welp, looks like I'll be doing two oil changes within a week. Never had this issue before, I normally use Mobile 1 but as mentioned, I had this oil handy and decided to use it at the time.
Old Nov 25, 2019 | 04:17 PM
travlee's Avatar
travlee
Master
Dang I miss the 4 quart (ish) days. The shop that built my car recommended joe gibbs oil.....at $11 a quart x 10 qts
Old Nov 25, 2019 | 06:22 PM
Brian_z33's Avatar
Brian_z33
Thats why you stay NA :P
Old Nov 25, 2019 | 08:03 PM
813_350Z's Avatar
813_350Z
no, that's why you stay with a Z and not a Corvette lol
Old Nov 26, 2019 | 12:20 AM
travlee's Avatar
travlee
Master
I dumped my z almost 5 years ago when it started becoming the new civivmc
All motor again, no more turbos
Old Nov 26, 2019 | 04:26 AM
masterjr33's Avatar
masterjr33
I would switch to a name brand oil...
I personally use Rotella T6.. I put that Shxt in everything i own/have owned.
works great.
