Oil foamy when doing oil change??
Old Nov 26, 2019 | 12:10 PM
Brian_z33's Avatar
Brian_z33
Originally Posted by masterjr33
I would switch to a name brand oil...
I personally use Rotella T6.. I put that Shxt in everything i own/have owned.
works great.
Has anyone heard anything good from Royal Purple? I ran it on my 300zx a couple years back but cant really remember how it was. Also, anyone have any tips on getting an accurate reading on these dipsticks? Im so frustrated lol. I read it first thing in the morning and it was half in between L and H so i topped it off bc i had like less than half a quart. Now it reads like the very top of dipstick lol
Old Nov 26, 2019 | 12:47 PM
813_350Z's Avatar
813_350Z
RP was always overpriced compared to M1 If you can find it cheaper than it will do just fine.
The Z is a PITA to get a good reading on due to the way Nissan's brilliant engineers designed this dipstick and it's location. I'd wait few hours until the oil has settled. When you add oil I believe it gets onto the stick which is now useless. I usually add oil with it removed though it still gives bad readings.
Once its settled lay it on a flat piece of papertowel in your hand. Fold the towel over onto it and slowly lift without moving the towel or stick. Line up the oil mark on the towel with the stick to get a basic reading.
Old Nov 27, 2019 | 06:21 AM
iideadeyeii's Avatar
iideadeyeii
Make sure car hasn't been started for a couple minutes. Pull stick, wipe with rag. Put in all the way, pull out and check
Old Jan 25, 2022 | 06:50 PM
Atjstballin's Avatar
Atjstballin
Default Having issue with my nismo
Hey guys, its about that mark where I do my oil change. Im using AmazonBasics full synthetic 5w-30 with K&N oil filter. Upon draining my oil, i noticed its foamy when draining from both plug and filter. Dipstick showed no foam and neither did fill cap. Is this something to be alarmed of? I have never had this issue and haven't experienced anything different in the way my Z runs. Its also taking a while to fully drain. Its been almost 10 mins and still keeps slowly draining.
my nismo has this foam after I shut off the engine after running. Did your foaming ever go away? This would really help me out im petrified
Old Jan 25, 2022 | 08:59 PM
Brian_z33's Avatar
Brian_z33
I sold my Z over a year ago but I just ended up replacing the oil with Mobil 1 Synthetic and oil filter. Didn't see anymore foam after that so that gave me some peace of mind. I would recommend the same to yours.
lilchief
Apr 26, 2011 09:24 PM
Spoiled Z
Aug 19, 2007 06:03 AM
Cannysage
Feb 26, 2007 11:58 AM
stops
Oct 15, 2005 11:54 AM
joeshow750
Mar 13, 2003 03:10 PM
