Coolant leak, wheres this connected?
Old Jan 11, 2020 | 02:36 PM
Marcø's Avatar
Marcø
Default Coolant leak, wheres this connected?
So my coolant is leaking and I filled it up 2 weeks ago I think. The reservoir is empty but the radiator is still full. I finally found where the leak is coming from but I wanna know what's in this area before I try to take it apart.
Old Jan 11, 2020 | 03:18 PM
dkmura's Avatar
dkmura
General & DIY Moderator
First thing to ask is how long has it been since you changed out the radiator cap?
Old Jan 11, 2020 | 03:52 PM
rustyschopshop's Avatar
rustyschopshop
That upper hose looks swollen, in the end of the hose seems to be coolant. Would recommend changing that and the radiator cap at the same time. Would also check your lower hose.
Old Jan 11, 2020 | 06:45 PM
Marcø's Avatar
Marcø
I've had the car for about a year. So I havent changed the cap.
Old Jan 11, 2020 | 06:48 PM
Marcø's Avatar
Marcø
I'll look into that, should I get a better hose or will OEM be fine?
Old Jan 11, 2020 | 06:53 PM
Marcø's Avatar
Marcø
So I found coolant under this part so i guess it's possible that the cap and/or the hose have gone like they've mentioned above. I'll check the bottom of it but I'll need a mirror.
asteroidgalaxy
Dec 13, 2017 09:08 AM
whistle
May 11, 2017 06:01 AM
AlphaZ33
Mar 6, 2016 06:22 PM
imp
Apr 4, 2011 10:39 AM
2boosted4u
Feb 1, 2008 08:16 AM
