Coolant leak?
Old Mar 30, 2020 | 09:52 AM
SpencerEvans's Avatar
SpencerEvans
Default Coolant leak?
Just bought a 2007 350z and after taking apart some stuff in the engine bay realized there was a puddle of green (my guess is washer fluid or coolant) under the battery that had pooled in the holder. Only drove the car home about an hour and the temps were fine, the coolant is definitely below the bottom line but nothing crazy on the reservoir tank. I’m kinda new to working on cars and not familiar with zs, any ideas? Thanks!
Old Mar 30, 2020 | 10:10 AM
dkmura's Avatar
dkmura
General & DIY Moderator
That's coolant, not washer fluid. Could be just leftover fluid from a change, but the only way to know is to clean it up and recheck for leaks.
Old Mar 30, 2020 | 11:18 AM
GreyZ's Avatar
GreyZ
It seems pretty unlikely for coolant to get in that area. Is there a chance that you have coolant in your washer fluid tank on accident??
Old Mar 30, 2020 | 12:48 PM
SpencerEvans
so after cleaning up the engine bay the coolant was everywhere all over the entire bay.. I just bought the car so I would hope the previous owner didn’t do that but it wouldn’t surprise me lol.. should I get a pressure tester and try to find the leak?
Old Mar 30, 2020 | 01:02 PM
SpencerEvans
After cleaning the whole engine bay everywhere had the coolant like everywhere.. could it have something to do with the radiator cap being faulty and spewing from there
Old Mar 30, 2020 | 01:25 PM
travlee's Avatar
travlee
Master
The joys of a used car. Is it possible, yeah, but the amount that was in the battery tray doubtful
Old Mar 30, 2020 | 02:09 PM
35th4me's Avatar
35th4me
Personally I would check coolant hoses. A small pinhole can spray fluid everywhere.
Old Mar 30, 2020 | 06:24 PM
SpencerEvans
Thanks for all the info im gonna get a tester tomorrow and hopefully find something😬
Old Mar 31, 2020 | 08:21 AM
jhc's Avatar
jhc
General & Tech Moderator
Might wanna do a visual inspection too- as stated above, get the car up to normal temp, open the hood with it running, look for pin-hole sprays or even larger leaks. (After topping off radiator/overflow when cold). Gl.
Old Mar 31, 2020 | 09:31 AM
SpencerEvans
After pressure testing the cooling system I found that the hoses leak a little at the ends but no spraying but the major issue is the radiator leaking at the top pretty good. Could this have caused the spraying effect that coated the entire engine bay or should I look somewhere else
Old Mar 31, 2020 | 09:59 AM
SpencerEvans
Any recommendations on radiators and hoses?
Old Mar 31, 2020 | 12:22 PM
jhc's Avatar
jhc
Not sure of your skills or budget. OEM will be easiest for radiator- plug and play. But start here, all solid providers-
https://www.z1motorsports.com/exhaus...-4_37_121.html
https://www.rockauto.com/en/catalog/...,radiator,2172
https://www.courtesyparts.com/auto-p...ing-system-cat
OEM or Z1 hoses should fit well and install easily. GL!
Old Mar 31, 2020 | 02:47 PM
GreyZ's Avatar
GreyZ
I just recently did the koyo rad swap on my HR. It was super easy. Hardest part is bleeding it once done.
This is the one I got.
https://www.amazon.com/Koyorad-V2999-High-Performance-Radiator/dp/B00GGCHY2S/ref=sr_1_1?dchild=1&keywords=v2999&qid=1585694802&sr=8-1 https://www.amazon.com/Koyorad-V2999-High-Performance-Radiator/dp/B00GGCHY2S/ref=sr_1_1?dchild=1&keywords=v2999&qid=1585694802&sr=8-1
Old Mar 31, 2020 | 04:27 PM
SpencerEvans
This is the one I got. https://www.amazon.com/Koyorad-V2999...5694802&sr=8-1
i just bought the Koyo rad some hoses and the metal bleeder.. was gonna go with mishimoto but heard it wasn’t quite plug and play any problems installing the Koyo rad
Old Mar 31, 2020 | 04:30 PM
GreyZ's Avatar
GreyZ
Not a single one. I did have someone helping which made it much easier. The hardest part is dealing with the condenser and getting it lined up when reinstalling. That and spilled coolant, but both of those were expected going in. I find it easy to remove the front bumper because it takes about 5 minutes and greatly simplifies getting everything lined back up on install.
Old Mar 31, 2020 | 04:33 PM
SpencerEvans
Thanks for the info I’m sure I’ll be back on here once i try to bleed the system not looking forward to that 🙃
Old Mar 31, 2020 | 04:43 PM
travlee's Avatar
travlee
Master
I personally would have monitored it before throwing parts at it, at most right now I would have done hoses and radiator cap
Old Mar 31, 2020 | 05:02 PM
35th4me's Avatar
35th4me
Did you notice the temperature gauge reading?
Old Apr 1, 2020 | 10:07 AM
SpencerEvans
I’m gonna be drifting the car so no need to take chances at it overheating and spraying coolant. Like 500 in parts is well worth it to know I’ll have a nice cool car on track but if I was just Sunday driving it yeah would probably just watch it.. when I drove it last time the temps were fine but I definitely wasn’t driving it hard at all
Old Apr 1, 2020 | 10:21 AM
travlee's Avatar
travlee
Master
get the power bleeder, or you will be making a thread that you are overheating
