Parking Lights Will Not Turn Off
Old Nov 16, 2020 | 04:28 PM
miggymcfly's Avatar
miggymcfly
Default Parking Lights Will Not Turn Off
So the parking lights (right headlight, tail light, and fender turn signal) stay on. I have tried multiple ways off checking from the fuses to the wiring. This happened right after I washed the vehicle for the first time. Help! I am stuck trying to turn them off. I do not want this issue to drain the battery.
Old Nov 16, 2020 | 04:42 PM
miggymcfly's Avatar
miggymcfly
Old Nov 16, 2020 | 05:00 PM
travlee's Avatar
travlee
Master
I doubt you have a 370..... also, don't double post
Old Nov 16, 2020 | 05:02 PM
miggymcfly's Avatar
miggymcfly
I do have one and my fault I'm new here so idk how to delete a post.
Old Nov 16, 2020 | 05:05 PM
travlee's Avatar
travlee
Master
You can't being new, but your other post were in the 350 area
Pm a mod and they can delete it. Wish ya the best of luck figuring out your issue. My guess would be ipdm
Old Nov 16, 2020 | 05:14 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Merged the two threads and placed them into the appropriate forum.
Old Nov 16, 2020 | 05:15 PM
miggymcfly's Avatar
miggymcfly
Thank you so much!
Old Nov 16, 2020 | 05:19 PM
travlee's Avatar
travlee
Master
Might want to post history of the car, how you were washing it etc
Old Nov 17, 2020 | 03:01 PM
miggymcfly's Avatar
miggymcfly
Here's a better description of my issue.
So I am having an issue with the whole right side of the turn signal not wanting to turn off when the engine is off. They do not flash, I checked the IPDM but not exactly sure as to which fuses or relay has gone bad. This happened when I washed the vehicle at one of those drive in bays. I noticed water was entering into the firewall grommet, so I fixed that problem. But the lights stay on. This morning, the battery died and I had to get a replacement. I would disconnect the negative terminal multiple times and still they shine. As of now, the battery is disconnected due to drainage. Not sure if it's the bulb cause the whole right side lights up.
If anyone knows the answer to my problem, some feedback would be appreciated. I've spent way too much on maintenance alone and I do not want to take it to the shop again. If it's an issue I could work on my own, I'd much rather do that. Thanks.
Sebastian777
Mar 7, 2017 05:48 PM
neox
Mar 6, 2013 02:07 PM
porschett
Dec 12, 2010 10:34 AM
icekube
Feb 17, 2005 11:27 AM
