Misfire and trouble accelerating
Old Dec 7, 2020 | 01:19 PM
Verokosky's Avatar
Verokosky
Default Misfire and trouble accelerating
Sorry I'm not sure how to use this forum yet.
I have a 2003 350z 6MT
​​180,000KM
I was driving the car just fine all day and as I was on the highway almost home I smelled gas for a brief second, I slowed down for the off ramp and as I started to accelerate again the car started to bog and have trouble accelerating slow or fast. The car runs fine at a constant speed only problems while trying to accelerate. At idle the car constantly back fires and mis fires. I replaced the coil packs and spark plugs 8 months ago. I have spares and tried switching the coil packs out. I also unplugged 1 at a time while the car was running and they all make a difference while unplugged. I had a p0300 code multiple cylinders misfire. While driving sometimes the check engine light will flash. The OBD reader I used said the 02 sensor and catalyst was incomplete.
any recommendations where to start ?
thank you.
Old Dec 7, 2020 | 05:14 PM
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
Do you know the maintenance history of the car? If you're running on original cats and injectors, you'll need to consider a healthy maintenance upgrade.
Old Feb 7, 2021 | 11:11 PM
JavanZ33's Avatar
JavanZ33
How bad are your O2 sensors? That may play into it.. I'm searching through forums trying to diagnose a similar issue myself. Just replaced all the coils and spark plugs with brand new oem spec, and still misfiring. Hope that you can get yours figured out..
JUSTINC2001
Sep 15, 2020 11:53 PM
LowZ33
May 8, 2020 03:45 PM
Kinkajou
Dec 1, 2018 09:09 PM
Pdj1183
Jun 12, 2018 11:11 AM
looq
Aug 28, 2014 02:45 AM
