rough idle white smoke from engine bay and tailpipe
Old Mar 28, 2022 | 05:14 PM
carter_Z33's Avatar
carter_Z33
Default rough idle white smoke from engine bay and tailpipe
so ive had a 2003 fairlaidyZ/350z for about 5 months now and parked the car and i left for a couple days and i come back to the catching a misfire and a really rough idle. so replaced the spark plugs and also noticed oil in the spark plug wells so replaced the valve covers and the ignition coils.
after i started it it still ran really bad and it sits way under 1k rpm wanting to die.
When i start it and let it warm up, i get white smoke coming from the engine bay and white smoke coming from the tailpipes
everything seems to poin to the headgasket but im not 100% i have not done a compression test yet.
Wondering if anyone else has had this problem and if you did what was your solution?
Old Mar 28, 2022 | 09:44 PM
bealljk's Avatar
bealljk
Yeah, white smoke is historically coolant in the combustion chamber…
Are you 100% sure you hooked up cylinder #4 and cylinder #6 coil pack connectors correctly?
Compression and leakdown test should help diagnose.
Unscrew your oil cap and do you see white-milky’ness on the underside of the cap?
Take some video / pics of the white smoke.
Are you pushing coolant out of the radiator/coolant overflow tank?
You could have moisture in your fuel tank / fuel that has some moisture in it - usually this is burnt off by the cats after warm-up.
Old Mar 29, 2022 | 03:14 PM
carter_Z33's Avatar
carter_Z33
Honestly thank you so much I had cylinder 4 plug into cylinder 6
Old Mar 29, 2022 | 05:21 PM
travlee's Avatar
travlee
Master
Pretty common an easily mistaken
Old Mar 30, 2022 | 08:56 AM
bealljk's Avatar
bealljk
I used a paint-pen and wront each cylinder connector bc this happens quite a bit - completely non-logical how nissan laid it out.
iheartmyz
Apr 10, 2020 08:28 AM
allmycarsdie
Jul 14, 2015 08:00 AM
02234546
Apr 13, 2013 08:10 PM
The_Laughing_Man
Sep 7, 2012 05:17 AM
shaddysalama
May 27, 2009 05:31 PM
