Camshaft timimg jumped..How to get back in time?
Old Jun 6, 2022 | 07:48 PM
Painterguy39's Avatar
Painterguy39
Default Camshaft timimg jumped..How to get back in time?
I posted this awhile back
Took a break from the car for awhile
Did Oil gallery gasket replacement
both sides cam timing jumped
PLEASE help me resolve this
I've heard about turning them backwards with a strap wrench using cam outer boss until everything is lined up again.
To be clear the chains never jumped,the cam/VVT assemblies rotated forward
Will/Can i damage a valve doing this/Clearance issues?
Thank you
someone on here has to have been through this?
2008 HR 32K
Old Jun 7, 2022 | 07:22 PM
Painterguy39
I thought we had engine builders on here.
Anyone?
Bueller?
Old Jun 8, 2022 | 06:02 AM
i8acobra's Avatar
i8acobra
The front cover still off? Use a 17mm socket on the bolt to rotate them back. If the bolt is tightened to the correct torque, it won't loosen.
Old Jun 8, 2022 | 07:05 PM
Painterguy39
Thank you very much..I am getting the same answer from others
I will probably use a strap wrench,but i see the procedure is the same.
StephenM57
Sep 4, 2023 12:51 PM
Zachattack615
Feb 3, 2020 03:11 AM
Thefbomb13
Jan 30, 2018 10:39 AM
KPierson
Mar 29, 2007 04:14 PM
ken350z
Jun 4, 2005 12:43 PM
