ECM fuse blows when you try and start the car
Old Jul 9, 2022 | 06:39 PM
candice350z's Avatar
candice350z
Default ECM fuse blows when you try and start the car
The other day I was driving my Z when it randomly shutoff. Suspected it was the fuel pump, replaced the fuel pump and the problem Persisted. I diagnosed that it was the ecm fuse so I replaced it and was able to cradle it home 3 fuses later. Now the car won’t even start without the fuse immediately blowing. I checked the o2 sensor wiring to see if it was grounding out but they all looked fine. Any ideas?
2005 350z 259,XXX miles
Old Jul 11, 2022 | 05:36 AM
iideadeyeii's Avatar
iideadeyeii
I'd unplug the o2 sensors and try again. Otherwise no idea.
Old Jul 11, 2022 | 11:54 AM
jhc's Avatar
jhc
General & Tech Moderator
What amp fuse does it call for and what amp are you using? Check your install and any grounds that aren't connected. This is a good time to buy/borrow an inexpensive multi tester.
Dereck Barnes
Apr 26, 2021 12:36 PM
r3dg3cko rob
May 9, 2014 07:20 AM
guvars
Aug 15, 2013 11:25 PM
03Zilverstone
Feb 2, 2008 05:22 PM
350zOnJuice
Apr 4, 2005 03:28 PM
