Issues with 2004 350z
Old Aug 9, 2022 | 04:42 AM
BFitz1999's Avatar
BFitz1999
Default Issues with 2004 350z
Recently having issues with my car starting and stalling. Sometimes it hesitates to start and most of the time it'll run at idle for a short time before it stalls. Used a scanner and it told me there was a fault with the cam sensors and so I replaced those. After I did that it still stalls but now when I touch the gas even slightly, the rpms rocket into the 3k range and will bounce back amd forth between 2.5 and 3k rpm like I'm 2 stepping. Also getting fault code for my ASCD switch. Any help would be greatly appreciated.
Old Aug 9, 2022 | 06:02 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Welcome- it would help if you post the mileage on your '04 Z and exactly what codes are showing up currently. Also, when did these problems first start, and were there any other issues that happened at the same time?
Old Aug 9, 2022 | 06:12 AM
travlee's Avatar
travlee
Master
oem camshaft sensors?
Old Aug 9, 2022 | 07:59 AM
BFitz1999's Avatar
BFitz1999
Thanks for responding, it has 142k miles on it and currently it's showing a P1564 code for my ASCD switch. And it started a couple weeks ago when I was driving home from work and the engine just lost all power for a second, then came back to life along with a check engine light, slip light and tcs off light. Ever since then it hasn't ran right, and stalls shortly after starting
BFitz1999's Avatar
BFitz1999
they are not oem
Old Aug 9, 2022 | 08:48 AM
iideadeyeii's Avatar
iideadeyeii
Get the OEM, aftermarket sensors have been known not to work at all.
Old Aug 9, 2022 | 09:40 AM
BFitz1999's Avatar
BFitz1999
do you believe this could be the sole cause of this issue?
Old Aug 9, 2022 | 09:44 AM
travlee's Avatar
travlee
Master
i would be willing to deadeye's money on it
Old Aug 11, 2022 | 01:58 PM
BFitz1999's Avatar
BFitz1999
update: got some oem ones and the throttle is still sensitive and does the 2 step thing
JotaroKujo
Jul 21, 2022 05:16 PM
Vikingmike84
Oct 29, 2019 04:02 PM
Dannyb209
Mar 15, 2019 03:06 PM
Wsheff
Apr 17, 2017 02:08 PM
Wsheff
Apr 15, 2017 04:50 PM
