350z clutch bleed problem
Old Nov 26, 2022 | 12:07 AM
Travioli's Avatar
Travioli
Default 350z clutch bleed problem
Hi there I have just tried to flush my clutch fluid and have run into a problem, I got my friend to push down on the clutch while I opened the slave cylinder nipple on the transmission I noticed that only a small amount of fluid came out so I did up the nut again and got my friend to pump the clutch to do it again but the clutch had no pressure any more and was just sticking to the ground I loosened the nut and again only a small amount of clutch fluid came out. in hindsight I realise that I didn’t pump the clutch before the first release but now my clutch has no pressure and I can’t flush out my fluid can someone help me?
Old Nov 26, 2022 | 05:05 PM
travlee's Avatar
travlee
Master
Push it down and manually pull it back up 15-20 times, then press and hold, crack nut, tighten it back....rinse and repeat
Old Nov 26, 2022 | 05:14 PM
Travioli's Avatar
Travioli
i have done this multiple times and still not working only slight amount of fluid comes out if not none i am thinking that my clutch master cylinder has ceased or something does this sound right ?
john1982
Aug 14, 2014 07:13 AM
ksuberk54
Sep 22, 2011 02:58 PM
josesantigo57
May 20, 2011 04:42 PM
Smokemall
Oct 14, 2010 03:30 PM
06VenomZ
Mar 12, 2010 11:43 AM
