Clutch kit Replacements
Old Apr 20, 2023 | 03:36 PM
travlee's Avatar
travlee
Master
Prob should replace the slave while at it
Old Apr 21, 2023 | 06:07 AM
i8acobra's Avatar
i8acobra
I'd start with just the clutch. Since the slave is external, it's easy to do the hydraulics later, if the clutch doesn't fix the problem. This is because he's on a budget.
Old Apr 21, 2023 | 06:44 AM
iideadeyeii's Avatar
iideadeyeii
Originally Posted by Jafet
I'm a little short of budget because it wasn't something I had in mind to change soon. Do you think that for a daily car use this clutch will work well for me?
https://www.ebay.com/itm/164355176269
I've ran this exact clutch without changing the oem flywheel @145k miles
https://www.ebay.com/itm/13264381359...Bk9SR_D8pMT0YQ
If you want to change the flywheel(you don't have to) I am using this flywheel
https://www.ebay.com/itm/13448873770...Bk9SR5qorMT0YQ
What you posted should work fine also. The cheap ebay clutch kits are all the same except the flywheel you have is heavier, so if you want to free up some hp you can opt for the more expensive flywheel, but if that doesn't matter then go with the cheapest option
nfrnks
Jul 29, 2017 09:19 AM
bgant3
Drivetrain
Nov 1, 2012 07:03 AM
priscilla ls1
Jun 8, 2012 08:17 AM
new2nismo
Wanted
May 24, 2011 07:12 PM
jcer
Aug 1, 2010 09:58 AM
