Splashing coolant!
Old Jun 6, 2023 | 06:00 PM
Meshawn N.'s Avatar
Meshawn N.
Default Splashing coolant!
My car has been overheating for a while and I’ve been trying to figure out why. Every time I try to burp the system, a lot of air seems to get pushed out of the no spill funnel once the car reached operating temperature. I changed the thermostat and water pump but nothing helped. I also keep checking my coolant levels and they never really dropped. I did a combustion gas test on the car also the fluid stayed blue so I don’t think it’s a head gasket, unless it could be but can’t be detected by the test I have no ideal, but anything helps. Thanks!
File Type: mov
Old Jun 7, 2023 | 01:47 AM
travlee's Avatar
travlee
Master
you still have air in the system
Old Jun 7, 2023 | 03:00 AM
Meshawn N.'s Avatar
Meshawn N.
so you think I should just let it run until it stops?
Old Jun 7, 2023 | 04:11 AM
travlee's Avatar
travlee
Master
plenty of tips and tricks... here is one example
https://my350z.com/forum/2003-2009-n...mpts-made.html
Old Jun 7, 2023 | 07:04 AM
Meshawn N.'s Avatar
Meshawn N.
I’ll try the put coolant directly into the blender screw, but then again still haven’t seen anyone else with that problem of coolant shooting out the funnel.
Old Jun 7, 2023 | 05:32 PM
BORNGEARHEAD's Avatar
BORNGEARHEAD
Old Jun 7, 2023 | 06:02 PM
Meshawn N.'s Avatar
Meshawn N.
Originally Posted by BORNGEARHEAD
watched this video too many times
Old Jun 9, 2023 | 07:58 AM
eZg's Avatar
eZg
damn....all you gotta do is search. try "Burp"
no spoon feeding here.
Old Jun 9, 2023 | 08:27 AM
Meshawn N.'s Avatar
Meshawn N.
Tf do you mean!? I’ve done all that and even attached a video showing what it’s doing (unless y’all can’t see that because I probably posted it wrong.) ain’t this suppose to be a community to help others in need? You making it seem like it’s not?
Old Jun 12, 2023 | 10:23 AM
eZg's Avatar
eZg
If you searched enough, you'd figure out that you just gotta keep cycling thru the steps. No need to freak out about a head gasket or anything. Lots of us have been through this.
Sorry if I came off as an *** but the info has been given to you. A couple times. Just keep at it.
Gl
Lord Shogun
Jul 31, 2015 01:57 PM
Pholicious
Mar 1, 2013 10:49 AM
JDMStanced
Sep 4, 2011 09:55 AM
RED RIDER
Oct 23, 2008 10:03 AM
mesulli
Oct 29, 2005 06:26 PM
