P0350 fault finding help
Old Jun 21, 2024 | 10:05 PM
Ericyyun's Avatar
Ericyyun
Default P0350 fault finding help
I got a p0350 code on my 2006 de. It seems to start and drive perfectly fine.
I’ve changed all the spark plugs then I got p0350 again along with p0301. So I changed the ignition coil one cylinder 1. Now when I start the car it struggles a bit and is lumpy when it starts. When I use a voltage detector it shows (50-1000v +) in all cylinders except cylinder 1 which only shows (10-49v). Previously when I first got the code it showed (50-1000v +) for all cylinders.
Would it be a faulty coil? It is brand new but not oem.
Thanks in advance for any suggestions and advice!
Old Jun 22, 2024 | 01:23 PM
Aeneas137's Avatar
Aeneas137
did you change the plugs before you got the error code or after? just wondering if maybe that cylinder 1 spark plug is bad. That would explain why the new coil didn't help.
Old Jun 22, 2024 | 01:55 PM
Ericyyun's Avatar
Ericyyun
I had the code before I changed the plugs
Old Jun 22, 2024 | 01:56 PM
Ericyyun's Avatar
Ericyyun
I had the code before changing the plugs
Old Jun 22, 2024 | 02:25 PM
Ericyyun's Avatar
Ericyyun
I noticed the spring in the new coil is not center. could this be not sitting on the plug properly and causing this issue?
Old Jun 23, 2024 | 02:28 PM
Aeneas137's Avatar
Aeneas137
you can just push it onto a loose spark plug to see if it goes on easily. without guessing what's happening down in the spark plug well.
Oklohomazociety
Apr 29, 2021 08:54 AM
LowZ33
May 8, 2020 03:45 PM
SoCali-Z
Jul 17, 2014 10:38 AM
Rick*K
Jun 17, 2013 05:37 AM
azmark30
Dec 6, 2012 11:23 PM
