Starts then dies
Old Aug 26, 2024 | 02:55 PM
I need somehelp's Avatar
I need somehelp
Default Starts then dies
I have a de and when i turn on the car it turns on and tries too die out i can press the throttle to keep it on but once i let go it slowly goes down in rpm and i unplugged the maf it turns on goes to 2k rpm after 30 seconds it dies i already changed maf, crankshaft and camshaft sensors. Also i changed the fuel pump and injectors.i looked at all the fuses and all of them are good and no codes thrown
Old Aug 26, 2024 | 04:24 PM
icer5160's Avatar
icer5160
So many things could cause behavior like this. Have you scanned the vehicle for codes? Are there aftermarket mods? What year and trim level?
-Icer
Old Aug 26, 2024 | 04:49 PM
I need somehelp
Yeah i checked for codes nothing pops up just a plenum spacer and test pipes its a 03 touring
Old Aug 26, 2024 | 05:43 PM
icer5160's Avatar
icer5160
You have the downstream O2 sensors connected & installed on the test Pipes? You really need a tune if you're running test pipes, otherwise the ECM will change AFR and timing in a negative way.
Without any codes to go off of, you're going to need access to a scan tool that can view live data and do advanced diagnostics. If a plenum spacer was installed, I would check for any vacuum leaks.
Also, if you replaced maf/cam/crank sensors, did you use OEM or some local parts brand? Always use OEM for major engine sensors on these vehicles. You're probably ok with the fuel pump, not sure about the injectors.
Always try to test and verify the problem before firing the parts canon.
Cheers!
-Icer
2008 Z33
Jul 24, 2023 05:06 AM
aguita
Oct 31, 2015 04:32 PM
SV350z
Jul 15, 2013 12:12 AM
nachospizza
Oct 19, 2012 12:45 AM
djamps
Tuning
Aug 18, 2011 11:01 AM
