Heater shut down @ stops
Old Mar 5, 2004 | 08:10 AM
ricka's Avatar
ricka
Default Heater shut down @ stops
I'm scheduled to drop my car again Monday, but...
While I drive my heater is great, but when I stop at a light the blower starts to blow cold. Once I start driving again it back to hot. Basically, I can't get heat while the car sits. Can anyone advise why this is happening so I can tell the dealer (who is clueless)?
Old Mar 5, 2004 | 08:45 AM
teh215's Avatar
teh215
You're probably low on coolant. Have you checked it?
Old Mar 5, 2004 | 08:49 AM
ricka's Avatar
ricka
I will now, but I checked it a week ago and it was fine and I had the problem then too.
Old Mar 5, 2004 | 09:57 AM
teh215's Avatar
teh215
Another alternative if the coolant level is fine is that the water pump itself is bad, or going bad.
Old Mar 5, 2004 | 11:49 AM
overZealous's Avatar
overZealous
Default Re: Heater shut down @ stops
Do you have the system on "auto" when this occurs or do you have it manually set to heat?
Old Mar 5, 2004 | 05:56 PM
ricka's Avatar
ricka
Default Re: Re: Heater shut down @ stops
I tried both and it blew cold on both settings
Old Mar 6, 2004 | 02:53 PM
azaz's Avatar
azaz
Sounds like it has an air pocket.
That will cause the problems you are having. If it was a waterpump then the car would indeed overheat and very quickly I might add.
You can look at the heater hose on the passenger side near the firewall and there is a bleeder on it. Open it up (MAKE SURE THE CAR IS NOT HOT!!!!) and see if air comes out. If not then close the valve and start car and open it slowly.(Don't take the bleeder all the way out, just till the coolant starts to seep out.)Let some of the coolant come out and it should push the air out with it. Accelerate the engine 2000 to 3000 rpm rapidly and should push the air out. Close the valve. Repeat if necessary.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Chris350z03
Oct 8, 2023 07:19 PM
pslamp32
Feb 8, 2017 09:07 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
