How to reset the ECU ?
Old Mar 12, 2004 | 06:03 AM
Webiteks's Avatar
Webiteks
Default How to reset the ECU ?
I just installed a JWT Pop Charger and wanted to reset my ECU because I hear that's a good thing to do.
I went to this link to look up the instructions:
http://www.technosquareinc.com/350reset.htm
Is it just me, or do those instructions confuse the crap out you? I understood the first part, but then the "learning procedures" confused me becuase I don't know if i'm supposed to incorporate those into the resetting procedure or what.
Can someone help me!?
Also....It says when you do it correctly, your check engine light will go off. The problem here is, My check engine light isn't on in the first place!
Hope someone can clear this up for me so I can do the reset.
Old Mar 13, 2004 | 09:30 AM
Infern0's Avatar
Infern0
lol, I'd never seen that. Looks like a good way to flood your engine.
Just think of the learning instructions as "callibration" instructions. You want to tell the car, where the pedal is going to be, when you aren't pushing it, and then tell the car where the pedal is going to be, when you have it all the way depressed. Just like calibrating a joystick, you gotta tell the computer what position the joystick is in when you want it to go left....etc.
Hope this helps. Not sure if the first part will reset the ECU or not....however, they are a fairly reputable company. You would not need to do any of the "learning" procedures if all you were doing is resetting ECU.
Old Mar 13, 2004 | 09:55 AM
Webiteks's Avatar
Webiteks
I'll have to play around with it today. I though for sure all I had to do is disconnect my negative terminal on the battery. Guess it wasn't that easy :-)
Old Mar 13, 2004 | 10:51 AM
EddieJr's Avatar
EddieJr
I installed a JWT Charger without resetting the ECU.
I think the resettting of the ECU was for mostly for older cars where the computers did not have as much active control over the timing and fuel delivery. The ECU would go into a learning mode after a cold boot.
Old Mar 13, 2004 | 10:55 AM
Webiteks's Avatar
Webiteks
Sounds good Eddie. I just wanted to get the full potential out of my JWT Charger. Have you or do you know of any one that had problems with their JWT Charger? I drive my car as a daily driver about 60miles/day minimum. I can't take any chances of anything going wrong
Old Mar 13, 2004 | 11:31 AM
s9am_me's Avatar
s9am_me
did you unplug the neg terminal when installing?? I don't know if its absolutely nessecary, but most installation instructions have it as the first thing to do. ppl here on the boards say to leave it off completly for 24hrs.
shifting to neutral at a high rpm resulting in the car to die out slowly is the only problem i've seen so far.
Old Mar 13, 2004 | 12:00 PM
EddieJr's Avatar
EddieJr
I haven't had any problems with mine. I drive mine to work occasionally 50+ miles on I-95. Speeds anywhere from 45-80MPH
and I have yet to have mine stall.
It actually has better throttle response with the POP charger.
No, I didn't disconnect the battery either.
Old Mar 13, 2004 | 12:06 PM
Webiteks's Avatar
Webiteks
Sounds like i'll leave it the way it is and see how things go.
Old Mar 15, 2004 | 01:17 PM
ZIABLO's Avatar
ZIABLO
I am Batman
For no reason at all my car just lost a LOT of power. I reset the ECU a few minutes ago and everything is back to normal. So you may want to reset your ecu...and maybe even then drive your car hard so your ecu learns your habits
Old Mar 15, 2004 | 02:18 PM
daking350's Avatar
daking350
People...I am not even going to touch this one it's just tooooooooo easy...
Old Mar 15, 2004 | 04:20 PM
Infern0's Avatar
Infern0
Go for it man....Knock yourself out.
Old Mar 20, 2004 | 11:43 AM
350 PILOT's Avatar
350 PILOT
I've read at this sight, that when you change the airflow into or out of the car, its a good idea to reset the ECU. Its not necessary because the computer will eventually learn the new setup. But manually resetting will speed the process. I installed dual exhaust and felt only a minor improvement in performance. When I reved my car I noticed smoke. After about 1 week (100 miles +/-) I stated to notice a significant improvement and the smoke was gone. Two days ago I installed a pop charger and man I really have smoke now. I'm going to reset the ECU this time
Old Mar 20, 2004 | 04:54 PM
350 PILOT's Avatar
350 PILOT
Well I did it and now no more smoke. Only drove it a couple of miles, so I don't know if there was any difference in performance. One thing for sure, it did run differently.
Old Jul 17, 2004 | 09:56 AM
ZSX's Avatar
ZSX
I've just done this with the technosquare instructions and if you follow the directions, it's cake. I suggest that you turn off the A/C, stereo, headlights, etc. before starting the procedure.
One thing the technosquare instructions fail to mention is that when the CEL starts blinking rapidly during the last step where the accelerator pedal is fully depressed, that's how you know the ECU has been successfully reset.
Then turn off the ignition for a few secs, start the car and leave the accessories off. Let it idle for at least five minutes and don't touch the accelerator. Then turn your accessories on and idle for a couple more minutes; then resume normal driving.
Old Jul 17, 2004 | 10:26 AM
ZIABLO's Avatar
ZIABLO
I am Batman
I followed the instructions 2 days ago, and if I remember correctly, they do tell you
Old Jul 19, 2004 | 08:04 PM
NiSmO D1X's Avatar
NiSmO D1X
Hey 350 pilot, are you resetting your ECU according to technosquare's instrustions or just disconnecting the battery...
Whiskers1996
Tuning
Aug 1, 2020 04:09 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
