RPM signal wire location
Old Mar 24, 2004 | 02:41 PM
NY 350Z's Avatar
NY 350Z
Default RPM signal wire location
i just got the pivot shift light system... i need to hook it up to my RPM Signal wire from the ECU. no results from search...
someone help me out please
Old Mar 24, 2004 | 04:01 PM
NY 350Z's Avatar
NY 350Z
i read its green and white comming from the ECU in the maxima,and it is the same in our car...
this is gonna kill me...no info about this on the net.
i should call nissan and ask them or is that a bad idea
Old Mar 24, 2004 | 06:41 PM
jesseenglish's Avatar
jesseenglish
There is no "RPM" wire because it goes into a combined signal wire, where a bunch of different signals are mux'd together and sent on a single wire.
There is a coil trigger wire however, but because there are six of them, one for each cylinder. It will be operating at 1/6th the RPM.
Cylinder 1's coil trigger wire is pin 62 coming out of the ECU. It's a yellow and red wire. Be careful, there are several yellow and red wires, make sure it's pin 62.
Old Mar 24, 2004 | 06:45 PM
NY 350Z's Avatar
NY 350Z
this seems harder than i thought...are the pins #'d? ive never messed with the ECU before...
do you think it will work properly if i connect the wire to it?
Old Mar 24, 2004 | 07:02 PM
jesseenglish
The pins aren't numbered. Here is a picture of what the connector that goes into the ECU looks like with the pin numbers on it.
I don't know if it will work because I don't know the specifics of that shift light. I'd call the company and tell them the only thing that is available as a trigger is a coil trigger pulse and mention the fact that there are six coils. Maybe you or they can reprogram it to adjust for the signal.
Old Mar 25, 2004 | 03:19 AM
NY 350Z's Avatar
NY 350Z
nice, thanks alot bro i appreciate it
Old Mar 25, 2004 | 03:37 AM
NY 350Z's Avatar
NY 350Z
i found this on the overboost website made by HKS...
http://www.overboost.com/obs/product...e%20Management
Old Mar 25, 2004 | 04:35 AM
jesseenglish
It's already a low level 5v signal. You should just be worrying about the signal frequency, not the voltage.
Old Mar 25, 2004 | 12:25 PM
NY 350Z's Avatar
NY 350Z
i called up nissan... 3 guys said i dont know and 2 said to hook it up to coil one...dont mess with the ECU its very sensitive. then i asked about the 1/6th rpm reading and they said it will work fine,if theres 2500 RPM's in coil 1,theres 2500 in coil 2,3, and so on. so im gonna give this a shot probably tomorrow night at the shop i work at unless its nice out,then i gotta go flying.
ill let you guys know the results and ill post pics/video of how the system looks and works. thank you
Old Mar 25, 2004 | 01:07 PM
jesseenglish
You don't have to mess with the ECU, just tap into the yellow red wire coming out of the ECU connector. Ensure you disconnect the battery when you do it.
Old Dec 3, 2020 | 01:00 AM
Z33DJB's Avatar
Z33DJB
Default Answer to all your problems. There is a signal wire you CAN TAP INTO.
Pin number 22 blue wire with orange stripe.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Stevo Z
Oct 3, 2015 09:14 PM
Tochigi_236
Sep 27, 2015 03:40 PM
