new engine due to oil consumption
Old Mar 24, 2004 | 05:57 PM
jefsali's Avatar
jefsali
Default new engine due to oil consumption
anyone else out there with this....
I also have a new problem with tire feathering....
Old Mar 24, 2004 | 06:00 PM
jefsali's Avatar
jefsali
just to add I have not ok'd the new engine due to many reasons, such as devalue and resale and the effect on the exhaust...
Old Mar 24, 2004 | 07:41 PM
Dissolved's Avatar
Dissolved
how much oil were you losing? I lose about half a court between oil changes
Old Mar 25, 2004 | 11:46 AM
jefsali's Avatar
jefsali
I was low 3 to 4 quarts between oil changes!!!!!
Old Mar 25, 2004 | 04:16 PM
Dissolved's Avatar
Dissolved
HOLY SH*T. How many miles on your z and what year?
Old Mar 25, 2004 | 04:39 PM
n8vz's Avatar
n8vz
really? VQ35DE only has a 5 quart capacity total. What brand of oil are you using?
Old Mar 25, 2004 | 08:01 PM
jefsali's Avatar
jefsali
yes, the HS is the word this is why nissan has approved a new engine. I did do the swithch to full syn after the first 3 to 4k. the syn oil is not the cause due to the fact that I had the problem before the switch. So, to all please get to know your dip stick and check your oil between changes. also, from my experience I had the oil light go on at least 6 times and I have been told that the oil light only goes on when you are at more than 3.5 guarts low.
Old Mar 25, 2004 | 08:36 PM
AmyCroft's Avatar
AmyCroft
Let us know what the autopsy finds.... Sound like broken ring lands on the pistons... For so much oil to go in 3750 miles..
Cheers Amy -
Old Mar 26, 2004 | 04:56 AM
mode101's Avatar
mode101
thats unreal .. to burn off 3-4 qts of oil, your car must have been blowing smoke ? was it leaking on the ground ?
Old Mar 26, 2004 | 11:09 AM
jefsali's Avatar
jefsali
No leaks, some smoke
Old Mar 26, 2004 | 03:29 PM
ronald_m's Avatar
ronald_m
Probably the valve didn't seat properly due to synthetic oil.
Old Mar 27, 2004 | 08:16 AM
jefsali's Avatar
jefsali
Had the issue of oil consumption before the switch to synthetic oil.
Old Mar 27, 2004 | 08:59 AM
hfm's Avatar
hfm
Default Re: new engine due to oil consumption
There are three that I know of with this problem. The fix is a new engine. Assuming you're in Arcadia, CA, I would recommend that you consult with Torrance Nissan even if you're already approved since they have previously done two engine replacements on Zs and have experience.
Old Mar 28, 2004 | 07:32 PM
Superfly84zx's Avatar
Superfly84zx
ronald_m: Valves that don't seat correctly will cause loss of compression... However, leaking or worn valve guides/seals will cause you to burn oil... synthetic oil will not cause this.
Old May 15, 2004 | 01:41 PM
corsair's Avatar
corsair
With each oil change I am losing more and more oil. In the last 3 changes I went from losing 1/2 quart to 3 quarts. I have a very early build date (see my sig) on my car so I am thinking that maybe I need a new enging if it is increasingly burning more and more oil. I do alot of highway driving and I drive the car hard, but 2 quarts of oil is excessive.
Old May 16, 2004 | 06:19 PM
corsair's Avatar
corsair
Default oil light comes on when 3.5 qts. low! WTF?
Are you serious? So basically you are running on 1.5 qts of oil before the ecu senses a problem?
Old May 17, 2004 | 01:10 AM
jefsali's Avatar
jefsali
yes, running on 1.5 qts before the engine light went on.
After a pain in the neck oil consumptions test, nissan has offered me a new engine to date, although I went to a bbb hearing to request a buy back--I don't want the car. I will find out soon what the decison is. I also have the alignment, pull to the right, feathering tires front and rear problems (I got 4 new tire replacements from nissan)
Old May 17, 2004 | 10:32 PM
onefastdoc's Avatar
onefastdoc
Do a search under my name and oil consumption. I've posted extensively on this and went through the exact same problem you did. Went through the BBB, NNA, Adam Goodman, etc., and ended up with a new engine (although I tried to get them to buyback the car).
No smoke, no leak, just losing about 3 quarts per 3000 miles. Did the normal break-in, no mods. This problem was noticed at the first oil change. My engine was replaced at 8700 miles.
You need a new engine, and Nissan needs to figure out what the hell is going on with their motors.
Old May 18, 2004 | 05:45 AM
mode101's Avatar
mode101
thats amazing, and this is one of the 10 best engines ???
Old Jul 15, 2004 | 04:36 PM
blinkygab's Avatar
blinkygab
same problem here - '03 Track w/ 26k miles. Nissan dealer just told me that I may need a new engine, and running another test to confirm.
Does anybody know what the new engine will do to the resale value of the vehicle? I'm assuming that it will leave a record in my vehicle history that people would be able to see on CARFAX.
