My Driverside Window Won't Roll Down
Old Mar 3, 2017 | 02:59 PM
zakmartin's Avatar
zakmartin
Originally Posted by Tomalam
not sure if this works for anyone out there, I had the problem recently where passenger window no longer works. Closing the door it doesn't move up to fill the gap either.
i was about to order a motor when I tried pulling up on the window control, held for 5 seconds, then press down on the window control and it rolled down and started working. Not sure if holding up on it for 5 seconds (like if you were trying to roll window up) reset it or something.
my problem was on passenger side, i held up on the window control from driver side but for the passenger window.
That's most likely going to be a temporary solution, at best. Let us know if/when the fix fails. If the fix holds, consider yourself blessed.
Old Mar 5, 2017 | 04:15 AM
92K1500's Avatar
92K1500
Holding the switch with the window not moving is a good way to fry the motor.
Obadabot
Jun 18, 2023 11:31 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
