Red lights on doors went out...
Old Oct 20, 2004 | 08:21 AM
Asterix's Avatar
Asterix
Default Red lights on doors went out...
So, has anyone seen this problem as well? Both red lights on my doors stopped working a couple of days ago. The map lights still work. There's a TSB for the map lights not working, but not for these red ones. I'd think that if the body control module crapped out, it'd take the map light with it.
Asterix
Old Oct 20, 2004 | 08:22 AM
orngez's Avatar
orngez
if you are talking about the red reflectors on the interior of the doors, they don't have lights in them
Old Oct 21, 2004 | 08:30 AM
Asterix's Avatar
Asterix
I could swear I've seen them on. They're rather pointless without lights. My old Supra has red door lights with lights in them. The service manual doesn't say anything clear, though it talks about these "Rear Floor Box Lamp" widgets. I'll take off the cover off one and look.
Asterix
Old Oct 21, 2004 | 07:34 PM
cpoe52's Avatar
cpoe52
They are just reflectors. Probably should have been designed with light bulbs behind the lenses.
Old Oct 21, 2004 | 10:41 PM
yobri's Avatar
yobri
Reflectors, just like the front sides on the front bumper. Cost-cutting to make the 350Z affordable
Old Oct 22, 2004 | 08:26 AM
Asterix's Avatar
Asterix
Well, I'll be. Maybe the next time the server goes down it'll take my post with it...
Asterix
Old Oct 22, 2004 | 08:14 PM
cpoe52's Avatar
cpoe52
No problem Asterix.
The only dumb question. is one not asked ;-)
Old Oct 22, 2004 | 08:43 PM
ChuckGZ's Avatar
ChuckGZ
lol... oops.
it makes me feel fetter to know that i'm not the only one who's posted something like this.
Old Oct 25, 2004 | 05:27 AM
Asterix's Avatar
Asterix
Since my '88 Supra has red lights on the doors that actually light, I figured the Z did too. I pulled out the driver's side reflector and there's nothing behind it. It'd be a great place to hide your stash, though...
Asterix
Old Oct 27, 2004 | 11:57 PM
ROME's Avatar
ROME
they light up?????????????
Old Oct 29, 2004 | 06:01 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
oh man...here we go again....
Old Oct 29, 2004 | 06:58 AM
yobri's Avatar
yobri
Read posts 2, 4, and 5 of this thread
Old Nov 26, 2004 | 11:51 AM
windydog's Avatar
windydog
Thanks Guys, I was about ready to pull my doors apart.
Old Nov 29, 2004 | 04:08 PM
LaidbackRacr's Avatar
LaidbackRacr
I worry about people sometimes It is so bad that I have seen dealer pages like courtesy stating that common problem is door lights out no worries they are just reflectors
Old Dec 7, 2004 | 05:47 PM
frankmusic's Avatar
frankmusic
Cool I did mine!
You certainly CAN add your very own courtesy door lights.
If you really want them installed in your Z, you must remove both door panels and the front kick panels as well. You will need to fabricate a bracket to hold them in place (just behind the OEM door reflector) Then find a suitable power source. (ex: cigarette lighter or other constant power source in fuse box area) The 350Z door switches currently supply the ground. Make sure that you connect both ground wires together. You will then allow either newly installed door light to illuminate simultaneously when driver or passenger door is opened.
Old Dec 8, 2004 | 05:04 AM
Asterix's Avatar
Asterix
Nice diagram, frankmusic. It's on my to-do list, but waaaaay down at the bottom. Since you connected the door switches together do both windows drop when you open one door? IIRC, that's the signal to that door to drop it's window. That's not really a problem, just a side effect.
Asterix
Old Dec 8, 2004 | 05:49 AM
frankmusic's Avatar
frankmusic
Cool That's how the Z should have been delivered.
Asterix
Thanks! I like the look. I was surprised that Nissan only chose to offer it as a reflector ONLY.
When I said, connect the two ground wires from the door switches - I was referring to the rubber switches located on the door jams. (not any switch "inside" the door)
For example; If you were to connect only one ground wire to its respective door exclusively, then only one courtesy door light would illuminate. By connecting both (door switch) ground wires to each other - both lights will illuminate simultaneously no matter what door you choose to open.
Old Dec 8, 2004 | 08:49 AM
Asterix's Avatar
Asterix
Yes, that's the one. The switch with the rubber bellows over it on the door frame. That's the switch that tells the computer to drop the window the 1/4" when you open the door. If you connect them together, won't the computer think both doors were opened and drop both windows?
Asterix
Old Dec 9, 2004 | 12:29 PM
LaidbackRacr
Asterix
Thats a nice little mod, Any idea what parts are gonna run for this complete set up
Old Dec 19, 2004 | 07:50 PM
ssc's Avatar
ssc
maybe it just me, but that seems like a lot of work for something that you hardly notice or need
