Pic request- Chargespeed Bottomline sides with VeilSide or Mines front lip
As the title suggests, I'm looking for any pictures of 350z's with both the Chargespeed Bottomline sides as well as the VeilSide v1 or Mines front lip. Specifically I'm curious to see how far, if any, the Bottomline sides hang lower than the front lip. Thanks in advance...
Slacking off at work and I found a few pictures of Duckeee's old setup. Front lip was Evo-r VSV1 (Veilside V1 type lip) if I remember correctly. Hopefully he doesn't mind me posting these here. What do y'all think? Flows well or looks mis-matched?
And as a reference, here is how my car currently sits with my "poor-man's" universal carbon fiber side splitters, which I am considering replacing with a set of Chargespeed splitters if I can convince myself it looks right:
Or do I just stick with what I have already?
Yeah that's what bothers me a bit...the Veilside/EvoR/Mines lip doesn't hang as low as the Chargespeed sides and that looks a bit weird from the straight-on profile angle. Meanwhile the CS sides do flow well with the Top Secret rear diffuser so it's a tough call.
I'm not sure if this helps, but here's a pic of my Chargespeed sides with a Varis Arising Lip. I've got more pics/different angles if you want them. I think the Veilside lips flows really well with CS sides. I had a replica V2 front bumper before I got my Varis lip and I didn't like how the "lip" on the bumper gets fatter as it wraps around the bumper and then the CS sides start out thin, if that makes sense.
^ Now that looks good! The Varis lip seems to sit a bit lower than the VS/EvoR/Mines lips. For example, I can see at the very corner of your front bumper where it starts to curve back in just above the top edge of the lip, at the wheel well (if that makes any sense), while the Mines lip sits higher and therefore covers that section of the bumper.
The Varis lip seems to sit at about the same height as the Chargespeed Bottomline front lip, which obviously was made to match these side skirts.
Do you have a feel for (or have measured) how much lower the bottom of the CS side skirt is compared to the bottom of the OEM side skirt itself? i.e. how much lower the CS sides hang relative to the OEM side skirt. If I had that value, I could lay it all out and really visualize how it will look with my Mines front lip.
i always wanted the charge speed sides, but i will never change the Veilside lip (your ex lip) just to match the charge speed sides. and i really dont want my sides to be lower than my front.. i think your setup sry is perfect.
Thanks! Yeah, when I look back up at the VS/Mines, I can see how it covers up that little section at the start of the wheel well. I haven't measured, but I can tell you it sits a good bit lower. I want to say that I've got around 3.5-4 inches from the ground to the bottom of the skirt. And the skirt sits about 2.5-3 inches below the OEM sides. I can check this weekend to give you a more accurate measurement if you'd want?
I personally like your set up as is... I will say the Chargespeed lip is almost too low though. Mine lasted 2 weeks and broke over uneven road, I almost cried. If you do the CS sides, might as well invest in the front too.
I love Duckee's setup - was one of my favorite Zs and I think it flows quite well.
I think the chargespeed sides would look great on your Z.
A possible option for you is the Amuse front? It fits well with the CS sides (should you choose to buy it) and TS diffuser imo.
This is member z2envy - hope he doesn't mind me posting!
I dont think it flows well st all. It looks like a hodge podge of parts, granted thats what it is. The front lip is way to high for those skirts as is the diffuser. Typically diffusers can "do their own thing" but only if the front and sides match (strictly aesthetically speaking). However in the event they don't, it just looks like random aero pieces with no flow...no bueno. The varis lip on the other hand is executed perfectly as they not only are the same height, but they appear to be close to/the same thickness. A diffuser on that setup would look exceptional.
(deleted pic)
(deleted pic)
Looking at it some more, I might not even be able to get in and out of the driveway without scraping the CS sides themselves. I dug up this pic of my car from the old days when I was lowered on Hotchkis springs (probably sitting 1" or so higher than current height) and had GReddy side skirts, and I only had maybe 2" of clearance between the side skirt and the 'apex' between the driveway and the sidewalk section. Those CS sides at my current height may actually scrape!
CFAUVEL
Oct 1, 2015 03:20 PM
