Driving to get an alignment yesterday...
Old Apr 20, 2006 | 02:01 AM
abstrakt's Avatar
abstrakt
Default Driving to get an alignment yesterday...
...and I was on 95 yesterday when the steering wheel started shaking so I angle my driver side mirror down and see that the driver side rear wheel seems to be wobbling. I tried to drive it slow to the shop since I was really close. I was going about 30mph in the right lane on 95 w/my hazards and then I heard two loud bangs so I pulled over. Everything looks fine from the outside, but I knew I was F'ed in the A. I call the tow truck and get towed to the shop. They pull the rear driver side wheel off and that F'IN spacer broke another stud and a third was bent all to hell. I broke the 1st one this past wknd when installing my suspension. Torqued the first spacer-nut to 80ft/lbs and the stud snapped so then went to 50 ft/lbs. Anyways, so the one that broke off yesterday fell back into my drum and chewed up the E-brake hardware. Car is sitting at the shop and will be there for a few days until parts arrive. I'm so pissed at that car...it's always something...Oh the spacers I have on the car now are the Project Kic's Spacers. I ordered a set of H&Rs off of the GB that's going on right now. So the lesson here is that you can't drive w/4 of the studs engaged on the spacer...you need ALL 5!
Old Apr 20, 2006 | 03:12 AM
Cockpit's Avatar
Cockpit
Sorry to hear about that!!! How much is all the damage???
Old Apr 20, 2006 | 03:20 AM
abstrakt's Avatar
abstrakt
It actually sounds a lot worse than it is...I'm going to get 5 new studs which should run me about $15 and I need to contact Nissan about the E-brake parts, but all I need for that is a bracket and a pin...which hopefully won't run me more than $30. The H&R spacers are $110 shipped in the GB.
Old Apr 20, 2006 | 03:47 AM
Driven1's Avatar
Driven1
Professional
What size spacers are you using? I can get aluminum spacers, and have a couple in 3mm and 5mm. Let me know.
Old Apr 20, 2006 | 05:16 AM
Sly_Z's Avatar
Sly_Z
Sorry to hear that Ab, I guess you won't be at the meet tomorrow night.
Old Apr 20, 2006 | 05:23 AM
abstrakt's Avatar
abstrakt
I'm running 15mm in the rears
Yea, Sly I don't think I'm going to have the car back until next week (Mon or Tues)
Old Apr 20, 2006 | 05:37 AM
Sly_Z's Avatar
Sly_Z
I can pick you up if you want me too...
Old Apr 20, 2006 | 05:38 AM
abstrakt's Avatar
abstrakt
I might try and catch a ride w/my girl and stop by for a little bit
Old Apr 20, 2006 | 05:59 AM
Noah@AAM's Avatar
Noah@AAM
I had teh same thing with my 15mm H&R spacers....destroyed the ebrake.....H&R sent me replacement studs 2 times and they we're all wrong...I bit the bullet and bought 60mm NISMO bolts...haven't had an issue yet!!!
Old Apr 20, 2006 | 06:54 AM
Silkk's Avatar
Silkk
Have had KICS spacers for about 6,000 miles now with no issues ( knock on wood ). Sorry to hear about it man, hopefully everything works out...
Old Apr 20, 2006 | 11:43 AM
djParis's Avatar
djParis
Retired Racer
Just curious what the biggest spacer is that you can run on stock lugs?
Old Apr 20, 2006 | 11:59 AM
Silkk's Avatar
Silkk
Stock studs?
I probably wouldn't space more than 5mm using the stock stud... 10mm+ you will need longer studs to be safe.
The Project KICS are nice b/c they are bolt on (10 mins) and have the elongated studs already secured. H&R you need to install the studs by disassembling the hub (I believe?), but they are still very nice spacers.
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
Depravity
Oct 1, 2015 04:49 PM
