Decent tire place? DC metro
Old Apr 9, 2007 | 03:21 PM
Driven1's Avatar
Driven1
Professional
Call Auto Effects, Inc. in College Park (301)345-1112 and ask for Rob. Tell him you're from the forum and that I told you to call and see if they can help. They're the most knowledgable wheel guys I know. They've been doing it a long time and have troubleshot some things similar to this for me before. Hope that helps.
Old Apr 9, 2007 | 03:52 PM
abui01's Avatar
abui01
Originally Posted by Freak
for some odd reason my Time Attacks wont hold air. when i got them one was completly flat so i filled it and sat it aside. next day flat again. i took it to Radial Tire in Silver Spring (came recommended by a few here) and they said they fixed it. they didnt. the tire is leaking around the bead slowly (my guess). they are all on the car now and the one i took to get fixed was filled at 32psi on Fri and is 23psi now. im not sure what needs done, but id like a reputable tire place to look at them. the wheels are expensive and i have $150 rays lugs id prefer not get scratched. also the car is lowered so a place with a lift that can accommodate lowered cars would be great also.
Happened to me, microscopic leaking. It's the tire itself and not the rim. Take the wheel off and put it on the ground. Mix up soap + water and throw it around the rim to check if bubbles appear. My suggestion: Get a new tire.
Old Apr 9, 2007 | 04:07 PM
Driven1's Avatar
Driven1
Professional
thas right above where you tint'd my Z right? i may just stop in tomm after work.
Yup. Thats them.
Old Apr 9, 2007 | 06:32 PM
abui01's Avatar
abui01
did that...did bubble up...took it the shop and they said they fixed it. i tried the soapy water again, no leaky. but im still losing air.
If it bubbles then it's a bad tire, you need to look extra extra close. The bubbles may not come right away because they're microscopic. Let it sit for 5 mins and you should see them come. Happens with many defective tires. You might even need a magnifying glass to catch them literally.
Old Apr 10, 2007 | 04:28 AM
DROPPEDIT2WCE's Avatar
DROPPEDIT2WCE
Submerge that pig in the bath tub, the rim may be craked or have a deffect...
www.nolimitbaltimore.com
Old Apr 10, 2007 | 11:16 AM
DROPPEDIT2WCE
Thats just strange, have you had the tire removed and "re-beaded" onto the wheel? Maybe try that particular tire on your other rim; if they are non directional tires... that will verify the rim's integrity. Just a thought
also just curious, what is the wheel width and tire size?
It could even be something simple like the valve stem or it's core is not installed properly or it may-be faulty.
350Z_Al
Oct 29, 2020 07:44 PM
kyin
Oct 15, 2015 05:54 AM
