Function:TUNED Summer Brake Special !Save 15% to 38%!
Function:TUNED
23571 Pebble Run Pl
Unit 145
Sterling, Va 20166
703.661.6162
sales@functiontuned.com
www.functiontuned.com
23571 Pebble Run Pl
Unit 145
Sterling, Va 20166
703.661.6162
Upgrade to Hawk Performance Pads
(Front and Rear)
Motul RBF600 Brake Fluid
(Front and Rear)
Hawk Performance is as a world leader in performance brake pads for both OEM and Aftermarket applications. Just a pad upgrade alone will make a significant improvement in your stopping performance. Hawk offers three different compounds for street use.
HPS
- High friction/torque hot or cold
- Gentle on rotors
- Very quiet, low noise
- Improved braking over OE pads
- Extended pad life
- Ultra-low dust
- Stable friction output
- Extremely quiet
- Extended pad life
- Increased rotor life
- Extremely high friction output
- Suitable for autocross events
- Race worthy for club racing
- Elevated temperature resistance
*Warning! Due to the dramatic friction levels produced by the HP Plus product to achieve "race-level" braking, rotor wear, noise, dust, and pad life may be affected.
Complete Brake System Flush
with your
Choice of Hawk Pads
Choice of Hawk Pads
(includes Parts and Install)
Non-Brembo
Hawk HPS Pads and RBF600 Fluid and Install
Regular
$401.06
Special - 15% Savings
$339
Hawk Ceramic Pads and RBF600 Fluid and Install
Regular
$412.80
$349
Hawk HP Plus* Pads and RBF600 Fluid and Install
Regular
$458.26
Special - 16% Savings
$385
Brembo
Regular
$457.30
Special - 17% Savings
$379
Regular
$467.45
$385
Regular
$522.19
$439
Add NEW OEM Rotors and Install*
Non-Brembo OEM Rotors
Regular
$294.75
Special - 25% Savings
$219
Brembo OEM Rotors
Regular
$1067.34
Special - 18% Savings
$869
Brembo Crossdrilled Rotors
Regular
$1452.55
Special - 38% Savings
$899
Rotors that are warped and can be turned will add a charge of $35 per rotor for turning. If rotors are out of spec and are unable to be turned down then a new set of rotors and install will need to be purchased.
*(At time of Brake Service Special as listed above)
Add StopTech Stainless Steel Brake Line Kit and Install*
Regular
$343.75
Special - 42% Savings
$199
Stainless lines are schweeet! I would highly recommend these for anyone that goes 100+ and back to 30-40 pedal feel is excellent, what I thought was brake fade was just expansion and contraction of the rubber OEM lines.
Bump for good specials, your brakes are the most important part of the car don't be a cheap a$$
Originally Posted by PumpedVA
Guess what guys you get to work on my brakes again next week. Sand rotors and replace pads good luck right?
Sanding iron rotors makes my boogers taste funny
I got some questions...
Do I need a appointment?
How much would it be ALL together if I had my brake pads and fluids changed, 30k maintence done, and had OEM brakes put on? (I have the brakes already)
