wider tires stock rim
Old Feb 22, 2008 | 04:45 PM
zeeroadster's Avatar
zeeroadster
Default wider tires stock rim
Ok, dont FLAME me here for this dumb question...but...
Can you put wider tires on the stock 07 rims?
Old Feb 22, 2008 | 04:55 PM
Eric the Ricer's Avatar
Eric the Ricer
i think you can go 245/265
Old Feb 22, 2008 | 05:25 PM
zeeroadster
Thanks..
Can anyone confirm this?
I ask because I like the look of the stock rims, and thought about doing wheel spacers to have the wheels look more flush, but I think wider ties would look better.
Any thoughts to help me out?
Old Feb 22, 2008 | 07:06 PM
Yes.
Old Feb 22, 2008 | 08:51 PM
zeeroadster
Ok, thanks Eric and David.
Then my next question is, would there be any issues with doing that?
Would it be considered a "normal fit" for the rim, or is it not recommended, but just doable?
Do you know of anyone who has done it?
Will it effect any other aspect of the car?
I appreciate the info.
Old Feb 22, 2008 | 09:21 PM
There is no perfect size tire for any wheel. Only a recommended range for contact patch and safety. For the Z I recommend OEM width plus or minus 10 mm.
If you want wider tires the right way to do it is get wider wheels.
Old Feb 22, 2008 | 09:31 PM
zeeroadster
Makes sense. I like the stock 18" front and 19" rear wheels that are on the Grand touring coupes...
thoughts on those?
Old Feb 22, 2008 | 09:45 PM
Eric the Ricer
you can always get the wheels widened. I thought about doing that with my track wheels actually. going 9 up front and 10.5 out back, it would be killer, but pricey
Old Feb 23, 2008 | 01:57 PM
zeeroadster
Can you give me a basic 101 on what offset and staggered are all about?
Old Feb 23, 2008 | 05:13 PM
halfass872's Avatar
halfass872
I have 265/40/18s on stock '06 rims (same as your '07 rims) They bulge a lil but seem to work fine! Look great too!! Have had zero problems with this set up!
Old Feb 23, 2008 | 05:20 PM
Yes.
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
Old Feb 23, 2008 | 07:38 PM
zeeroadster
excellent... any negative issues at all? Have long have you had them on there? What do you mean by they bulge a little?
zeeroadster
Yes.
thanks, its appreciated.
Old Feb 24, 2008 | 01:10 AM
halfass872's Avatar
halfass872
Only had thm on a couple months. By bulge i mean cause the tread is wider then the rim. So it gives the look of bein a lil concave on the sidewall cause of where the bead of the tire sits on the rim. It's not bad looking. I actually like it, i think it gives it an agressive look. A different tire may not do that. I have goodyear eagle F1 GS-d3's.
I'm out of town now otherswise i'd take pics for ya.
People say you can go as wide as 275, but i think that'd be unsafe at that point, on our stock rim size.
Old Feb 24, 2008 | 07:16 AM
zeeroadster
Interesting..yeah, would lke to see some pics when you get a chance.
Have a safe trip.
Old Feb 24, 2008 | 12:47 PM
halfass872's Avatar
halfass872
Have a safe trip.
Thanks!
I'll shoot some for ya next weekend.
Old Feb 25, 2008 | 03:19 AM
KManZ's Avatar
KManZ
+1 on the stock '07 rims. I like them as well, and was going to go the same route when the time came to replace the stockers. Wheel spacers and a wider tire should look ok, but probably not as good as a wider rim.
Any issues with using spacers? Can the suspension components handle them?
Old Feb 25, 2008 | 04:26 AM
4SHIZZIL's Avatar
4SHIZZIL
suspension can handle it...the only concerns are the spacers themselves. If they break or crack...now you have lose wheels. For the most part the upgrades in metal and heating have almost elimiated such possibilities. But heck even a rim has the chance of breaking..very slim, but possible.
I just would not go too large on the spacers....also plan on uneven tire wear.
I do own a pair of 5mm that I will put on the front one of these days....lol
now that I lowerd the front I want to push the wheels out around a half inch.
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
