help!sweating my balls off
Old Jun 7, 2008 | 10:26 AM
HKS-Z's Avatar
HKS-Z
Backroad Pro
Angry help!sweating my ***** off
so up until yesturday it felt good in my house with the windows open-but now that its 95 ,i shut all the windows and turned the a/c on,and leave for couple hours-come back and the house is still a sauna. so i check the breakers and reset them just in case,then try again. still its not cool in my house. WTF-the unit is running outside and i even tried the lowest setting.Somebody told me that it may need recharged?is there such a thing?I duno anyting about Hvac,and i cant call the landlord till monday.is there anything i can check.
Old Jun 7, 2008 | 10:33 AM
03aeroZ's Avatar
03aeroZ
needs a recharge, any heating and cooling company can do it. not sure how this works when you are renting though.....not sure if you can pay to get it recharged then send him the bill....doubt it.
Old Jun 7, 2008 | 10:48 AM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Is there ice on the unit at all? If so, turn it off, let the ice melt. Then turn it back on. Don't turn it way down though or it'll just ice up again.
Old Jun 7, 2008 | 10:51 AM
Jokestrap's Avatar
Jokestrap
Landlord should fix it. Call 'em. Unless you have an "as is" lease agreement. Doh!
Old Jun 7, 2008 | 10:57 AM
Ex2cinaZ's Avatar
Ex2cinaZ
Destructo Girl
lol just say *** it, pick up some cold beer and go to my house
Old Jun 7, 2008 | 10:58 AM
HKS-Z's Avatar
HKS-Z
Backroad Pro
^no ice-first time the unit has been on since ive lived here(moved in january).
The heat never worked well either-it had to be up to 80 to get the house temp at 72..there is a tbe thats all f*cked up off the unit-maybe its just a drian?
Old Jun 7, 2008 | 10:59 AM
108NismoZ's Avatar
108NismoZ
+1 i've been fuking bored all day. all the laundry is pretty well done now! see now what you have gone and made do..no hurry up get over here!
Old Jun 7, 2008 | 11:00 AM
HKS-Z's Avatar
HKS-Z
Backroad Pro
They are "out of reach" until monday
Old Jun 7, 2008 | 11:06 AM
HKS-Z's Avatar
HKS-Z
Backroad Pro
Since the wifey took my carto work-i'll just cool off in her's the old fashinoned way.
Old Jun 7, 2008 | 11:44 AM
MrsHks-Z's Avatar
MrsHks-Z
^^^Thats My little DIRTY 2!!!! Its nice to take the Z every now and then when i can pry the keys out of his hand...
Old Jun 7, 2008 | 03:43 PM
If the interior is 87 degrees, it will take hours to get to 77 degrees. You have to cool everything: furniture, walls, air, everything.
Old Jun 7, 2008 | 04:54 PM
TreeFiddyZee
Do WHAAAAT!?
The air coming out of your register should be meat-freezing cold. I just stuck a thermometer in my register and it read 53.8°. GL with it. I went through this last year in the middle of July. It cost me $5900.
Old Jun 7, 2008 | 05:00 PM
Eric the Ricer's Avatar
Eric the Ricer
If it makes you feel any better, my apartment is a cool 69 degrees right now
Old Jun 7, 2008 | 05:44 PM
spddmn124's Avatar
spddmn124
just goto starbucks or something, or your friends and chill until your house is little more "viable"
Old Jun 7, 2008 | 06:43 PM
Driven1's Avatar
Driven1
Professional
It's a little late for today but the line you're showing broken appears to be the drain (not a big deal if thats what it is). The insulated line and coil are the ones you want to be concerned with.
Are you running on a heatpump system? Check the filter and if it's a heatpump also check the water filter as well as sometimes they get clogged as well? When it's running is just the fan running or will it blow cold for 90 seconds and then cutoff (the fan will still run but under the cooling function it will typical sound slightly louder) and then blow hot? Most of the time it's a regulator located outside by the fan unit with will run you about $350 installed.
Good Luck...unfortunately HVAC does not qualify as "emergency" unless you're elderly.
Old Jun 7, 2008 | 07:30 PM
Lv2DC_Z's Avatar
Lv2DC_Z
SpecOneSociety
Ok this happened to me at base housin... there should be an inside... unit where u change the filter n everthing... normaly in the hall or what ever... when you turned it on did u set it pretty cold if so the insideunit froze ... turn on ur heater full blast suck it up and listen for dripping. Cuz could be a lot of ice melting.... try that and if no inside portion then forget this message lol n e ways you can't turnit up to low.... condensation plus shiver cold equals hella ice...
Old Jun 9, 2008 | 12:31 PM
DROPPEDIT2WCE's Avatar
DROPPEDIT2WCE
I have a firend who owns Olympic Heating and air in Kingsville, he does some sidework at resonable rates. Let me know if you need his numerals
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
Row2K
North East Marketplace
Dec 27, 2015 12:09 PM
bcoffee20
Nov 19, 2015 06:39 PM
TrackFiddy
Sep 24, 2015 09:36 AM
CrowzRSA
Sep 21, 2015 04:00 PM
