2006 slave cylinder issues
Old Jan 7, 2009 | 07:32 AM
NissanDrifter06's Avatar
NissanDrifter06
let me know if that works for you. because that could also fix my problem..
Old Jan 7, 2009 | 09:00 AM
Ex2cinaZ's Avatar
Ex2cinaZ
Destructo Girl
Originally Posted by NissanDrifter06
Ex2cinaZ, my clutch does the same thing, when i rev above 5 grand or rev to about 6500 it sticks. i cant go to a drag strip because when i have to burnout to get my tires hot for grip my clutch starts to suck to the floor and stick until i let off the gas.....any ideas?? slave cylinder maybe?
I've had this exact problem with both of my z's 06 and 07 ... i've had the slave cylinder replaced in both vehicles to no avail. The only thing that totally solved the issue was dropping a JWT clutch and flywheel into the 06 roadster. I'm still running factory clutch in my 07 and if I dump it it will stick to the floor. You CAN go to the drag strip you just need to learn how to feather your clutch out instead of dumping it. As far as I know there's no fix to the pedal sticking to the floor issue- the pedal does not release from the floor when you let off the throttle... how long have you had the car?
Old Jan 7, 2009 | 09:11 AM
NX2KDET's Avatar
NX2KDET
Cpt. Nauti Raw
Keep in mind ^^^^^^^^^^This chick races in 6" heels!!!
deviljon's Avatar
deviljon
get the slave and master cylinders replaced. got that covered under warranty for my 06 base as well. good luck.
Old Jan 7, 2009 | 09:12 AM
Ex2cinaZ's Avatar
Ex2cinaZ
Destructo Girl
is there any other way to do it?
(lol actually i break out the doc martins at the track)
Old Jan 7, 2009 | 09:14 AM
NX2KDET's Avatar
NX2KDET
Cpt. Nauti Raw
I have never heard of the master cylinder going back, hell besides the earlier 240sx's I have never heard of them going bad on any nissans. But slave cylinders go all the time.
Old Jan 7, 2009 | 09:19 AM
Ex2cinaZ's Avatar
Ex2cinaZ
Destructo Girl
Replacing the slave cylinder is not going to solve the problem of the clutch pedal sticking to the floor on hard launches.
Old Jan 7, 2009 | 09:31 AM
NX2KDET's Avatar
NX2KDET
Cpt. Nauti Raw
I got a 15psi wastegate spring you can jimmy rig under neath the clutch pedal
Old Jan 7, 2009 | 09:46 AM
Ex2cinaZ's Avatar
Ex2cinaZ
Destructo Girl
problem solved!
Old Jan 7, 2009 | 11:01 AM
NissanDrifter06
well i went to my dealership and told them that my clutch was having problems and they told me that warranty doesnt cover clutches....is that true?? my bumper to bumper basic warrenty is expired on the 11th of jan...and the dealership is closed ><. but i still have my other warranty like my powertrain 96,000 or 5 years.
Old Jan 7, 2009 | 11:03 AM
Driven1's Avatar
Driven1
Professional
YES. Just like brakes, etc. Considered normal wear and tear unless defective.
Old Jan 7, 2009 | 11:06 AM
NissanDrifter06
well crap, i thought clutches were under warranty.
Old Jan 7, 2009 | 11:08 AM
Ex2cinaZ's Avatar
Ex2cinaZ
Destructo Girl
no... they'll cover the clutch if you are within your 12 month 12,000 mile period and something fails causing damage to your clutch. In my case... slave cylinder leaked all the fluid out and everything siezed together. Since the slave cylinder is a covered component and caused subsequent damage to the clutch it was replaced.
Old Jan 7, 2009 | 11:20 AM
NissanDrifter06
ah, well my 350z has 32,000 miles on it and its an 06. so im way past that warranty. i just wanted the mechanics at the dealership to look at it and tell me what is wrong exactly and then i can figure out what to do about it. since my clutch only sticks when i dump the clutch i wasnt going to tell the dealership that hahah. i just asked if my clutch was within warranty and it wasnt.
Old Jan 30, 2009 | 06:33 PM
haleo's Avatar
haleo
i have the dealer from h*** 06 had less than 5k miles and already PAID for new clutch . car had foul odor in garage after every drive smells like burning clutch (maybe fluid) car now has 6200 miles (yes 6200)andnothing has changed stil has odor . i am thinking about suing in small claims court and would like to join in class action suit if any body can direct me to those parties i can sure use the help iam sick of this car and dealer
Old Feb 2, 2009 | 05:06 PM
NissanDrifter06
the dealership not do anything about it? your car should still be under warrenty. my warrenty expired...so now i gotta figure out what exactly is wrong with my clutch and figure out how to fix it.
07ZEKE
Aug 23, 2021 09:15 PM
sherm
Apr 11, 2020 05:21 PM
3vilbunny
Jul 18, 2017 05:10 PM
350z82
Oct 1, 2015 06:25 PM
