Installing seat harnesses?
Old Jul 9, 2008 | 07:25 AM
Pun1sh3RZ's Avatar
Pun1sh3RZ
Default Installing seat harnesses?
I searched and the threads I came across didn't help a whole lot, anyone local know how to install seat harnesses? Let me know I will compensate
Old Jul 9, 2008 | 08:34 AM
NX2KDET's Avatar
NX2KDET
Cpt. Nauti Raw
The top harness go on the harness bar the sides go on the rails and the front (5 or 6) you have to drill and use the O bolts that come with it and run the harness thru them.
Old Jul 9, 2008 | 08:36 AM
Pun1sh3RZ's Avatar
Pun1sh3RZ
yeah I got the lap harnesses in fine, the shoulder harness though I was getting frustrated with. Guess you have to undo the buckle and re-tighten through the harness bar
Old Jul 9, 2008 | 10:19 AM
matt240sx's Avatar
matt240sx
http://www.jegs.com/instructions/471...essinstall.pdf
http://www.stockcarracing.com/howto/.../photo_06.html
To tighten the harness you pull down on the strap after you go through the turn-buckle part the second time. Hard to explain. 4-5 point harness is a ***** on the street. My brother has them in his 240sx. It's hard to get anything thats not within your reach.
Old Jul 9, 2008 | 10:25 AM
Pun1sh3RZ's Avatar
Pun1sh3RZ
second link might be of help, thanks Matt.
Old Jul 9, 2008 | 01:01 PM
matt240sx's Avatar
matt240sx
If you need any more help let me know, we installed them on my brothers S13 so I might be able to help. Are you using a harness bar?
Old Jul 9, 2008 | 01:04 PM
Pun1sh3RZ's Avatar
Pun1sh3RZ
yes.. help me!! haha and yeah sparco harness bar
Old Jul 9, 2008 | 05:25 PM
Akabeth's Avatar
Akabeth
Noob question.
For a simple Sparco configuration, do all we need is just a harness (6pt or whatever) and a harness bar? I am absolutely new to this after market stuff and after looking at the Sparco harness bar manual, the installation seems to be just a simple bolt on. But on the harness itself all I see "on the product page" is just the nylon harness... what am I suppose to use to bolt it on to the harness bar or the car???? and how's the installation supposed to be like?
(Sorry I'm really confused here)
Edit: Pardon me. I missed this entirely
So I am supposed to drill a hole in the floor next to the seat base?
Old Jul 9, 2008 | 05:42 PM
Pun1sh3RZ's Avatar
Pun1sh3RZ
Just got my harnesses in right!!!!!!!!!!!!! What a pain in the a$$
Old Jul 9, 2008 | 07:17 PM
H4RDCOR3's Avatar
H4RDCOR3
how did you mount them?
Old Jul 9, 2008 | 07:22 PM
Pun1sh3RZ's Avatar
Pun1sh3RZ
come over and check em out
Old Jul 9, 2008 | 07:23 PM
.steeeeZ33.'s Avatar
.steeeeZ33.
@ J&D auto
the Z has special mounting plates behind the seats.
robbie ( driven1) has harness without the bar.... nasty car.
Old Jul 9, 2008 | 07:24 PM
Pun1sh3RZ's Avatar
Pun1sh3RZ
wish I would have known that oh well
Old Jul 9, 2008 | 07:30 PM
.steeeeZ33.
@ J&D auto
harness bar is cooler lookkng tho haha.. bryce, what seats are u using?
Old Jul 9, 2008 | 07:33 PM
Driven1's Avatar
Driven1
Professional
And it is NOT the way it should be done. VERY unsafe and for show at the time. They have since changed. At the time I used the factory mounting points.
The proper way is with a harness bar or using long harnesses using points farther back in the rear strut tower. Keeping the "pull point" 10 degrees or less from 90 to the back of the seat.
If you do not do this and get into an accident you run the risk of the belts pulling down on you and compressing your spine...NOT good.
Edit: FWIW...Points 5 and 6 (groin belts) should be mounted using the provided "O" bolts and 90 degrees and inline with the bracing in the bottom of the seat. Appropriate seats have the bracing built in.
Old Jul 9, 2008 | 07:44 PM
Pun1sh3RZ's Avatar
Pun1sh3RZ
threw in the Corbeau ones i'm selling until my new ones come in
Old Jul 10, 2008 | 01:44 AM
Nowell's Avatar
Nowell
National Z Club
and be advised you can still get a ticket for no belt. When I had my cage and harnesses, I still got a ticket from a Henrico Co cop. You wont pass inspection either unless your originals are still in and usable.
Old Jul 10, 2008 | 04:50 AM
bigslim350Z's Avatar
bigslim350Z
or you can get a full SCCA roll cage and mount the harness to the cage bar that runs behind the seats?
Old Jul 10, 2008 | 04:59 AM
Pun1sh3RZ's Avatar
Pun1sh3RZ
ghey
Old Jul 10, 2008 | 05:23 AM
ExtaZ33's Avatar
ExtaZ33
Subscribing. Pics of how the lap belts are mounted and pics of how they mount to the Sparco harness bar would help me out a ton. I have it all ready for install just don't know exactly how to tackle the project.
