utec manual map selector run clock or counter clock?
Old Oct 31, 2008 | 04:52 PM
nizzy350's Avatar
nizzy350
Default utec manual map selector run clock or counter clock?
Ok need some help. Got a Utec and I dont know where map 0 and 1-9 are.
I imagine 0 is dead left. The little **** points straight up, but the dial is to the left. Kind of like this -|. Pretty sure that is 0.
From there if I wanted to go to map 1, would I go one click clockwise or counterclockwise>?
thanks,
t
Old Oct 31, 2008 | 06:51 PM
str8dum1's Avatar
str8dum1
when you connect to it with your laptop, it will tell you what map you are on.
i wouldnt let anyone else guess for you.
Old Nov 4, 2008 | 12:56 PM
Mike@Altered's Avatar
Mike@Altered
The map selector dial, localed on the actual UTEC, has a cuttout on the dial which allows you to see through the dial and what map you are on. The numbers increase clockwise.
However, it is highly recommended that you plug your computer into the UTEC and look at the UTEC's "Dashboard". Here it will tell you which map the UTEC is actually using. We recommend this becuase we've seen several instances of the UTEC's optional switch saying the UTEC should be on one map, when it was really on another.
Hope this helps,
apex locator
Jul 23, 2021 02:27 AM
2ndchanceZ
Oct 26, 2015 08:03 PM
