Strut bar problem - Help
Old Mar 20, 2009 | 03:47 PM
Lv2DC_Z's Avatar
Lv2DC_Z
SpecOneSociety
Default Strut bar problem - Help
My wife and I installed the plenum spacer today. Well when we tried to put the right side of the strut bar on it would not allow the bolts to go in correctly. The bolts only went in half way and was basicly stuck. I was able to get them out. Is there some thing i can do i need to move the strut bar closer in. I know there are 3 nuts on the bar but, I am not sure how to make it shorter. Please help 350z gods.
Old Mar 20, 2009 | 03:54 PM
iStan's Avatar
iStan
ZR
My rendiition of a strut bar, passenger side to driver's side {-o-o-o--------}
Loosen up the out side bolts. This should allow you to start turning the passenger side of the strut bar. I believe you should spin back to front if you're holding passenger side to your left side. This will decrease the length of the strut bar. Once everything is on, use the middle nut to loosen/tighten as needed. The outside bolts are to lock it in place.
Hmm, LV2DC huh? I may be doing that soon as well.
Old Mar 20, 2009 | 04:27 PM
Lv2DC_Z's Avatar
Lv2DC_Z
SpecOneSociety
Thank you very much the problem is fixed. ... but the new bolts kinda stripped the holes but the old shorter bolts ( thanks for my wife helpin me and giving me the idea) fit and worked perfect
Old Mar 20, 2009 | 07:15 PM
The suspension has settled. Its different than when you took the bar off. I believe this is the nut that makes the bar shorter. Don't force anything. I pushed down on the fender, and all the bolts fell in place.
Old Mar 20, 2009 | 07:19 PM
lbz's Avatar
lbz
How cool is that the wifey helps with the mods...
Old Mar 20, 2009 | 07:35 PM
WhiskeyHotel's Avatar
WhiskeyHotel
Pretty dang cool...
Old Mar 20, 2009 | 08:23 PM
Lv2DC_Z's Avatar
Lv2DC_Z
SpecOneSociety
I was like damn, after i said man i need 2 ppl for this ... extra hands. my wife said . we can both do it.
She keeps wantin me to get a blow off valve for the car.... lol i told her we need turbo for it... she is like thats only 1k right ..... lol
Old Mar 21, 2009 | 01:18 PM
Glock-Star's Avatar
Glock-Star
x5
Old Mar 21, 2009 | 03:24 PM
terps's Avatar
terps
glad you got it fixed, i heard you sometimes need to jack the front end up so the frames not under tension, meh atleast you got it workin
Old Mar 27, 2009 | 08:56 AM
Toby-22's Avatar
Toby-22
Aww man my stupid self forced it in and now both the bolt and holes are stripped!!! Also i have the 5/16 plenum spacer and i hate putting on the washers, is there a strut bar that is higher than stock so i wouldn't have to use these washers?
Old Mar 27, 2009 | 12:58 PM
abui01's Avatar
abui01
I have a greddy strut bar that's thinner than the stock bar which allows more clearance w/o spacers. PM me if anyone wants it.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
