Help car won't start
Old Jun 25, 2010 | 04:23 PM
jeffie7's Avatar
jeffie7
Originally Posted by i3aog
and no don't have a sister lol
mẹ?
Old Jun 26, 2010 | 01:01 PM
i3aog's Avatar
i3aog
Okay, so got new battery today. Still no help. Same symptoms of the car cranking but it just won't turn over. I'm running out of ideas. Anybody have any suggestions
Old Jun 26, 2010 | 01:30 PM
abui01's Avatar
abui01
Have someone crank the car and check if the car has spark. that would require you to remove a coil. If spark is ok when cranking but still not starting it is possible that the car may not be getting fuel. The fuel pump may not work at times. When the car does not crank see if you can rubber mallet or kick underneath on the fuel tank, or remove the covering in the glove box behind the pass. seat and with your hand bang the top of the fuel pump. If the car starts up after or during cranking then its poss. fuel pump. I recommend to crank while banging the pump. But The cam/crank sensor's might be faulty as well. Usually with that you would have some type of CEL and code. Try the lock/unlock trick, but it may be poss that your key has become out of wack and may need to be reprogrammed for the anti theft module to be recognized. Simple things to check though are if the car gets no fuel or no spark. That would narrow down what to look for after the fact.
Old Jun 26, 2010 | 02:32 PM
i3aog's Avatar
i3aog
Yea I checked that yesterday, car is gettin fuel. Tried 3 diff spark plugs and 3 diff coils, none of them ever sparked while tryin to start the car. Tried a fresh coil and spark plug and it still wouldn't spark.
Old Jun 26, 2010 | 04:03 PM
huyrua's Avatar
huyrua
Dumah!! Is your car AT or MT? If it is MT than it could be your clutch switch.
https://my350z.com/forum/maintenance...ce-please.html
Old Jun 27, 2010 | 05:30 AM
djamps's Avatar
djamps
If it were the clutch switch it wouldn't crank at all.
I'm leaning towards a blown fuse, check all of 'em, under the hood and in the driver kick panel.
Old Jun 27, 2010 | 11:11 AM
i3aog's Avatar
i3aog
Yea car cranks so its not the clutch switch, checked all fuses and relays...they're all fine. I'm leaning towards a bad crank sensor.
Old Jun 27, 2010 | 12:33 PM
abui01's Avatar
abui01
got a OBD II scanner? it should pop up with something.
Old Jun 28, 2010 | 01:30 PM
PlatinumSR20's Avatar
PlatinumSR20
if you have a CEL present, I can scan it for you...
Old Jun 29, 2010 | 03:24 AM
350Ricky's Avatar
350Ricky
I like Rice
Re-check all your fuses, I had that happen to me awhile ago.
Old Jun 29, 2010 | 08:44 PM
i3aog's Avatar
i3aog
Thanks for all of the helpful input. Turns out it was the key immobilizer system. Seems like it dropped the key I was using and wouldn't register anything else. When I switched out the battery it reset I'm assuming. Then the second key I had worked like a charm.
aarrgghh
May 1, 2022 11:04 AM
Katie93
Sep 15, 2015 05:57 PM
RyansZ33
Sep 15, 2015 05:54 AM
Darkspy
Sep 7, 2015 09:09 PM
