Control Arm Bushings
Old Jun 30, 2010 | 05:20 AM
WYZIWYG's Avatar
WYZIWYG
Default Control Arm Bushings
Still can't figure out why my front [driver's side] control arm is knocking. One possible suggestion was the bushing may be worn out [on a 5 y/o vehicle???]. Anyone know if i can buy new bushings at the NISSAN service/parts department?
Old Jun 30, 2010 | 05:23 AM
jeffie7's Avatar
jeffie7
call and ask or look at the online parts listings for nissan parts just google it
Old Jun 30, 2010 | 05:32 AM
WYZIWYG's Avatar
WYZIWYG
On the phone [on hold] with them right now.
edit: No they don't sell them separate. Fawwwk!!!!!!!!
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
it's a common issue on Z's and G's - the inner is particularly prone to failure, though the outer is known to go as well particularly on lowered cars. It's inexpensive and easy to fix though
the bushings are not replaceable from Nissan directly - they only sell the complete control arm.
Whiteline and SPL offer replacements
Whiteline: https://my350z.com/forum/suspension/...-bushings.html
inner Whitelines are in stock, outers are currently backordered till id to late July from what we're told
SPL: http://z1auto.com/prodmore.asp?model...ng&prodid=4136
are available
Old Jun 30, 2010 | 07:22 AM
abui01's Avatar
abui01
Just buy the cusco arms and call it a day. Never had a problem with bushings on mine.
There is also a Nismo bushing set from Nissan that replaces all the bushings in your entire car. Might be like a 2k labor job to do that, but its very worth it!
Old Jun 30, 2010 | 07:26 AM
WYZIWYG's Avatar
WYZIWYG
^Just downloaded some options from *********. I'm still puzzled why they[control arms] decided to go out and if being up on jackstands as opposed to a lift played any role in this.
Old Jun 30, 2010 | 07:32 AM
bb1314's Avatar
bb1314
da Terminator!
http://www.trademotion.com/partlocat...?siteid=214252
Old Jun 30, 2010 | 07:38 AM
WYZIWYG's Avatar
WYZIWYG
^Thanks E10. The Parts Dept where i usually go for service said i was the first one to ever ask about replacing bushings and that they are only sold with a new control arm and not separately.
Old Jun 30, 2010 | 07:52 AM
blasian's Avatar
blasian
Are you talking about the lower control arm bushing where the shock bolts through?
Old Jun 30, 2010 | 07:59 AM
WYZIWYG's Avatar
WYZIWYG
Front A arms. I'm just gonna replace them since they were probably due anyways....
Old Jun 30, 2010 | 08:01 AM
blasian's Avatar
blasian
Damn that sucks.
Old Jun 30, 2010 | 12:24 PM
Barnabas's Avatar
Barnabas
National Z Club President
get the cusco's that what I have they are easy to adjust and problem free...
O and they are pretty blue soo you get ricer points
Old Jun 30, 2010 | 06:02 PM
jeffie7's Avatar
jeffie7
Both jack stands and a lift would hold the car up in the air using jack points. when a car is lifted the suspension will sag, my guess is when it was sagging one of the bushings tore? not really sure what could have happened, but either way whatever broke must have been on its way out.
Old Jun 30, 2010 | 07:27 PM
WYZIWYG's Avatar
WYZIWYG
Old Jun 30, 2010 | 07:35 PM
Chen's Avatar
Chen
Suspension is meant to support a vehicles body but since its in the air it cant and i'm assuming your wheels where on while jeff did the tp it would cause the control arm to sag. It was probably on its way out.
Old Jul 1, 2010 | 12:25 PM
WYZIWYG's Avatar
WYZIWYG
Default HALP!!!
HALP!!!!! Ok, i found a set of Cusco front control arms online listing at $429, but then I found a set of Meagans for $288 that "seem" just as good.
http://www.350zupgrades.com/advanced...h9p9i8n8iepp91
Is is just a matter of the name brand that justifies the higher cost or does anyone know if the Cuscos are better? And does anyone have a link to some cheaper ones? Paul said $400 sounded high for these.
Old Jul 1, 2010 | 12:28 PM
Barnabas's Avatar
Barnabas
those megan's do not have the same adjustablity of the Cuscos....
did you PM vendors on here for prices?? I got mine from adam at Z1
Old Jul 1, 2010 | 12:31 PM
AcidJake75's Avatar
AcidJake75
Living in 350Z
if your dropped - might as well get the rears too..
Old Jul 1, 2010 | 12:40 PM
WYZIWYG's Avatar
WYZIWYG
Already got SPC camber/toe mods in the rear....
Old Jul 1, 2010 | 12:49 PM
Z1 Performance
Former Sponsor
the Cusco pricing all changed for 2010, so has gone up vs this time last year (about a $40 difference)
