Motorsports The Z in its Natural Habitat
1/4 Mile racing question about spare tire
Old Mar 18, 2003 | 08:40 PM
TIGHT-Z's Avatar
TIGHT-Z
Question 1/4 Mile racing question about spare tire
Hey I have quick question. Im going to the track on Saturday and I was wondering will it make that much of a difference if i take the spare tire out versus leaving it in???
Old Mar 19, 2003 | 10:09 AM
TIGHT-Z's Avatar
TIGHT-Z
Default ?
Anyone know if it makes a difference???
Old Mar 19, 2003 | 10:19 AM
EWOOD420's Avatar
EWOOD420
any weight reduction is good........
Removing the spare tire is something I typically do when I go to the drag strip
Old Mar 19, 2003 | 10:46 AM
Last WS6's Avatar
Last WS6
Remove all your excess weight. Spare,jack(if you guys have one) arrive at the track with a little less than 1/4 tank of gas and you are ready to roll.
Old Mar 19, 2003 | 11:56 AM
jester's Avatar
jester
The only thing I disagree with is the gas....
Last time I was at the track with my old 95GT....anything less then 1/4 tank of gas, and I had issues hooking up...I was running street tires also.
Half a tank seemed to be about right...by the time I got done running I was down to about 1/4 tank....before traction be came a real issue.
Old Mar 19, 2003 | 01:21 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
You may be better off putting higher octane gas from the track if they are available. That will give you more hp and I think you will benifit more from that than removing tires.. But if you do both, then you are in the 13's with proper traction!!
Old Mar 19, 2003 | 02:00 PM
Oh4aZ's Avatar
Oh4aZ
That is a good question about removing the spare tire for when you go to the track. As already mentioned, it is good to have as much weight reduction as possible, but at the same time, you don't want to run into traction problems.
I am going to the track on March 30th. I am going to try it both ways. I'll have about 1/4 of gas and I'll try a run with and without the spare and jack and see if the benefit of less weight outweighs the risk of poor traction (no pun intended)
Old Mar 19, 2003 | 03:47 PM
JamRWS6's Avatar
JamRWS6
That is not correct....unless you are running a super high compression engine (which the Z cars aren't) or are using forced induction.....adding octane will probably HURT you not help you.
Why do people think race gas is going to help a car designed for pump gas?? It makes no sense.
Old Mar 19, 2003 | 05:52 PM
Last WS6's Avatar
Last WS6
I only have the drivers seat in my car. 1/4 tank of gas. LOst 20 pounds since last season on a diet. i hope to pull some good times this saturday.
Old Mar 20, 2003 | 03:44 AM
jester's Avatar
jester
or if your able to bump the timing up on a N/A engine ....but then again....it's not really necessary to run THAT much timing
just being a pain, sorry
Old Mar 20, 2003 | 01:46 PM
zogan's Avatar
zogan
would a injen CAI be considered a forced induction???
Old Mar 21, 2003 | 05:14 AM
jester's Avatar
jester
No...SuperCharge, Turbo = forced induction.
Old Mar 21, 2003 | 05:35 AM
j's350z's Avatar
j's350z
Default Race Gas
Sport Compact Car Mag got around 3 more HP when they dyno'd the car with 100 octane gas over the 92 premium they were running. So, inconclusion, our Z's MAY run better with race gas. I'm not saying to go out and put 110 in it, but once in while 100 may not hurt....
bcoffee20
Nov 19, 2015 06:39 PM
Bodyboarder81
Sep 21, 2015 06:23 AM
