Motorsports The Z in its Natural Habitat
Performance vs. Track vs. Enthusiast...in 1/4 mile
Old Apr 14, 2003 | 06:08 PM
orhanz33's Avatar
orhanz33
Default Performance vs. Track vs. Enthusiast...in 1/4 mile
Who's running the best times? I know every drivers diff...I ask cuz...
Performance (18's) heavy?
Track (18's) lightweight
Enthusiast (17's) smaller diameter rims, and lighter then performance rims...
or do any of the stock rims have very little/no effect on the times?
Old Apr 14, 2003 | 06:35 PM
ares's Avatar
ares
Veteran
it should matter, but I dont think anyones run 2 different cars on the same day, and comparing different people at different tracks is too hard to know for sure. but im sure it matters.
Old Apr 14, 2003 | 07:32 PM
zogan's Avatar
zogan
I thought base was running the quickest, then the track, but they are so close, it all depends on the conditions and the driver, there is prob. no way to compare
Old Apr 14, 2003 | 07:38 PM
Anthz's Avatar
Anthz
I can help answer this. Two us did it just last week, I drive a stock performance and went to rivercity raceway with DeviousZ, who has a stock track model. We ran neck and neck to whole way. 14.11 @100.49mph to his 14.07 @100.51mph. Here is the link..
https://my350z.com/forum/showthread....threadid=25594
Old Apr 15, 2003 | 07:49 AM
c5chris's Avatar
c5chris
The weight difference of the wheels arent enough to put a big dent on ETs. Just as the other post said, it depends mostly on driver's skill when youre comparing the same car which basically the 3 models you had metioned.
If you are gonna make wheels an issue, I can tell you that drag radials are bigger, heavier but stickier and have a larger contact point thus they are better for drag racing.
The only difference with the 3 models would be handling due to the wheels. 18s would have an edge due to a larger contact patch but I doubt that it will make a big difference. Tire tread configuration has more to do with it, esp on a skid pad. The 18s have a noticeable harshness on the ride though coz of the stiffer tire sidewall.
Old Apr 15, 2003 | 08:24 AM
ares's Avatar
ares
Veteran
actually the big fat 18s might suffer from bad traction when they float over bumps. the tracks wont, and the 17s should be better.
tires weight will affect ET, they are rotational mass, since the stock 18s are about 27lbs, and a set of lightweight like track rims or other forged rims are about 18, your looking at near 40lbs of lost weight. a significant difference all by itself, but then when you consider that they are unsprung weight, youd be hard pressed to find a better place to lose weight.
Old Apr 15, 2003 | 08:33 AM
TIGHT-Z's Avatar
TIGHT-Z
Default Base is the quickest
I have the Base model and I got that simply because it is the lightest one. I have been to the track many times and my best time was 13.9@101
Old Apr 15, 2003 | 08:37 AM
350zSpeedRacer's Avatar
350zSpeedRacer
This should be in the Racing Section. Thread moved.
Old Apr 15, 2003 | 01:53 PM
92hatchattack's Avatar
92hatchattack
how were you guys launching to get those track times--- getting ready to take her to the track, and ide like to get some practice first!
Old Apr 15, 2003 | 08:41 PM
orhanz33's Avatar
orhanz33
thanks guys
kyin
Oct 15, 2015 05:54 AM
Tochigi_236
Sep 27, 2015 03:40 PM
