NA Build Inside....Soup to Nuts :)
Old Jul 12, 2007 | 07:58 AM
  #181
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Originally Posted by MI 35th
sony image mixer = super easy to use software and makes things quickly
cool! Any idea where to get it?
Old Jul 12, 2007 | 07:59 AM
  #182
Z1 Performance
Former Sponsor
Originally Posted by NA&CH
Chaging it up big time Adam. I remember back with you bought the Works. I still have those pics saved on my comp. Car looked awesome. I am sure it will not dissapoint anyone Goodluck on the body work, getting ready for HIN, and the new tune. Can't wait to see it "revealed."
Thanks again for the efforts
Chris
O and wheres the damn Vids...
Now we're on a different set of Works...I think you guys will like it!
Old Jul 12, 2007 | 08:03 AM
  #183
Motormouth's Avatar
Motormouth
I thought you had those magnesium blue TE37s... or your headlights??
I am very jealous as I am pretty heavily in the NA fan camp... this article is like porno for me http://www.jdm-option.com/eng/featur...2/z33_v35.html
everything you did, I think about and it turned out a lot like I thought it would in my head. I think there are a couple more hp for you as well, so your fun isn't done yet.
and remember, it's only the FI guys that are all about the drama
Old Jul 12, 2007 | 08:19 AM
  #184
Z1 Performance
Former Sponsor
The Mag Blue 19 inch TE's and Mag Blue headlights, and the Ohlins, etc., are going on Kwame's car. You think my motor is badass, wait till you see his later on this year
Old Jul 12, 2007 | 08:43 AM
  #185
MI 35th's Avatar
MI 35th
OGPremierMafia
what type of camera do you have?
I have the sony dvd handy cam and it works excellent, but it will interface with any usb ported in camera, I have the software somewhere around here, If I find it, I just send it to ya, I never registered it so it should work, I just ask that youn dont register it.
Ill PM you if I find it.
ImageMixer.com has the updates, but not the base program.
Pixela is the parent comp of the program they have a image mixer 2.0 I think for 49.99 if you want to look into that, I have also been playing around with windows ,movie maker that is installed on most comps, it should do the job, here is the link...
http://www.microsoft.com/windowsxp/d...viemaker2.mspx
Old Jul 12, 2007 | 08:47 AM
  #186
Z1 Performance
Former Sponsor
thanks - its a model TVR something....from about 99 (got it before going to Japan for the first time). Was quite expensive back then (around $1000), and its a digital 8. It uses a firewire connection, which I know is not too big of a deal, as I am sure the local compuse has a firewire to usb plug I can get.
I tried Sony's site but they don't have the software for mine anymore...I know I had it at some point, but no idea where it is. Perhaps I still even have the box for it at home, so I will double check that
Old Jul 12, 2007 | 08:52 AM
  #187
MI 35th's Avatar
MI 35th
OGPremierMafia
most new computers should be able pnp with the camera, but the editing software has to recognize it. I think you might wanna try window movie maker first since its free.
Old Jul 13, 2007 | 05:28 AM
  #188
NA&CH's Avatar
NA&CH
I was just thinking of having my RG's mag blue'd and my headlights to match.
Is Kwames car going NA also?
Chris
Old Jul 13, 2007 | 06:24 AM
  #189
Z1 Performance
Former Sponsor
yes
Old Jul 13, 2007 | 07:41 AM
  #190
Kwame's Avatar
Kwame
Chris
Old Jul 13, 2007 | 07:43 AM
  #191
__jb's Avatar
__jb
Z + Rear Seat
Adam, I see you are using a UTEC to control your engine management. Is a separate piggy-back device like a UTEC required due to the larger MAF pipe, or do you think the new Osiris firmware flash would be sufficient?
I would like to incorporate some of your designs, like the 3" MAF, and am trying to decide if I should just start off with a UTEC, or if the Osiris software would work. Either way, I plan on having it professionally tuned on a dyno. (After the Osiris Tuner Kit is available.)
Old Jul 13, 2007 | 07:47 AM
  #192
Z1 Performance
Former Sponsor
the 3 inch MAF will honestly be a waste of time unless you have the head and cam package to go with it. Otherwise, having played with both, it's not worth the effort or expense.
Can the Osiris handle the MAF? I would assume so, based on what I know about it. Will it work better/worse than a UTEC remains to be seen.
Old Jul 13, 2007 | 08:27 AM
  #193
__jb's Avatar
__jb
Z + Rear Seat
Thanks for the honest answer, Adam.
I don't know if I'll ever put cams in my car. Are your cams smooth and driveable? I always associate high lift and longer duration with poor idle and a general lopeyness in the lower RPM ranges. Maybe that's not true of modern cams for the VQ.
If I was ever to install cams, I would upgrade the heads, too. Anyway, I enjoy reading about your project! Keep up the good work!
Old Jul 13, 2007 | 08:33 AM
  #194
Kwame's Avatar
Kwame
His motor is smoother than a stock motor. No kidding.
Old Jul 13, 2007 | 08:35 AM
  #195
Z1 Performance
Former Sponsor
there is definitely a lope to them, so you know the car has cams. All I had to do was bump the idle up and do the TPS reset it holds the idle fine, never stalling, a/c on and off
Some cams will be less lopy, some more. It's not only the duration that matters, but also how the lobe itself is cut. The steeper the ramp angle, the lopier (sp? ) the cam will be
In terms of how the engine itself feels...it literally is smooth as silk. 0 vibrations in the cabin, even with the lope, from idle to redline. That's all due to the balance of the internals
Old Jul 13, 2007 | 10:14 AM
  #196
Frostydc4's Avatar
Frostydc4
^^^ What do you have the idle set to?
Old Jul 13, 2007 | 10:22 AM
  #197
Motormouth's Avatar
Motormouth
I will guess either 750 or 900
Old Jul 13, 2007 | 11:10 AM
  #198
rkd350z's Avatar
rkd350z
please hit 320whp... i'll pray for you..
Old Jul 13, 2007 | 11:24 AM
  #199
Z1 Performance
Former Sponsor
idles at 940
Old Jul 13, 2007 | 11:50 AM
  #200
Kwame's Avatar
Kwame
This car will hit 320 in time. After that we will go hunting for some C6 Corvettes
