NA Build Inside....Soup to Nuts :)
Old Jan 23, 2011 | 05:51 AM
  #1121
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
it's ~10 degrees out and has been been snowing on and off for weeks - car is inside and staying there for the forseeable future. I've driven it twice in the last 8 weeks
The Ohlibs are without question the best setup I've used to date on these cars. Awide range of height adjustment, zero noise, very meaningful dampening adjustments. No other coilover I've used has impressed me as much in the last 7 years. My previous HKS RS will be up for sale soon.
Old Jan 23, 2011 | 10:04 PM
  #1122
leozim's Avatar
leozim
The Ohlibs are without question the best setup I've used to date on these cars. A Ronnie height adjustment, zero noise, very meaningful dampening adjustment. No other coilover I've used has impressed me as much in the last 7 years. My previous HKS RS will be up for sale soon.
thanks for the response. well hopefully you get the same weather as we have soon you could do a bit of testing and review on the new set up. pros, cons, specs etc.
Old Jan 25, 2011 | 08:37 AM
  #1123
Z1 Performance
Former Sponsor
not quite sure what other details you are after - the pros are as I've described. The only con is the price, as they are expensive. Spec wise, what specs are you after?
Old Jan 25, 2011 | 08:00 PM
  #1124
tuko316's Avatar
tuko316
Hey Adam I'm curious how many miles have you driven with this motor so far? How often do you take it to redline? Any concerns as far as reliability of the motor itself?
Old Jan 26, 2011 | 04:44 AM
  #1125
Z1 Performance
Former Sponsor
approximately 18,000 miles since July 2007
Often - it makes power to cleanly to redline, and since it was built to be at, and sustain the higher rpms, there is no real reason not to take it there. Of course I don't spend the time driving in the car racing up to redline, but it's taken up there all the time.
at this point, none, since it's not new and has proven reliable, though there are never any guarantees - at the end of the day, it's just a machine, and machines can break
Old Jan 26, 2011 | 02:20 PM
  #1126
tuko316's Avatar
tuko316
Thanks for the reply.
After reading about someone on the maxima forum havin their oil pump shatter revving upto 8k+ with a stock bottom end I was a little concerned.
Old Jan 27, 2011 | 05:26 AM
  #1127
Z1 Performance
Former Sponsor
A stock oil pump is designed for stock revs (or slightly higher) on a stock bottom end. The components Nissan uses, the way Nissan balances stock components, and the revs they are balanced to, is alot difference than the same components and tolerances you assemble a built motor to. Proper clearances for bearings, balancing of all rotating components, etc etc is crucial if the engine is to survive high rpm use in the long term. Nothing special about my oil pump - just a standard revup. You could put the worlds greatest oil pump on an otherwise stock engine, and the vibrations that the stock engine produce at 8000 rpm (where it was never designed to rev), could just as easily trash that bad-*** pump. Everything has to be designed/assembled to work as a unit, no single part will save an engine from itself if you are using it in an environment beyond it's capabilities.
Old Feb 1, 2011 | 05:34 AM
  #1128
jmccarty's Avatar
jmccarty
Good testament for my now >30,000km DE oil pump still "knock on wood" hanging in there with the Cosworth set-up!
Old Feb 1, 2011 | 05:54 AM
  #1129
e30cabrio's Avatar
e30cabrio
I am going with BC stage 1 cams, Supertech dual valve springs on my 88mm BC crank with BC rods and 96.5mm 11.0.1 JE pistons.
I am looking for input now on the right head gasket bore and oil pump to use.
Some say use 98mm HG, some say get a custom 96.5.
Any input would be gratefully accepted.
Old Feb 1, 2011 | 06:00 AM
  #1130
tuko316's Avatar
tuko316
98mm would be good. A good engine builder would take a 96mm head gasket and slightly enlarge the bore. This way in the combustion chamber the headgasket doesn't heat up and cause pre detonation.
Old Feb 1, 2011 | 06:20 AM
  #1131
jmccarty's Avatar
jmccarty
I have a 96mm Cosworth head gasket set. We added a bigger water cooler and a oil cooler with catch can when doing my mental build. There must be an increase in compression from 98 to 96mm so more heat. It never get's even close to what the original oil and water temp gauged (new analog) DE engine ran at now so this may help to some extent if you tighten the gap. If I'm wrong on this, please anyone?
Old Feb 1, 2011 | 08:15 AM
  #1132
Zazz93's Avatar
Zazz93
I thought a .5 mm oversize was the appropriate HG size. So your 96.5 pistons would ideally go with a 97mm HG, but I don't think I've ever seen that size out there. I have seen a few 96.5's but I don't know whether they can take an overbore of the gasket. Also note, some people have matched the HG to the piston bore and been ok, e.g. 96.5mm pistons and 96.5mm HG. I think this would depend more on the piston itself though.
**Correction Z-1 Performance sells a 97mm from HKS, but has a thickness of .7. See if the numbers work out for your project.
Old Feb 2, 2011 | 01:53 PM
  #1133
e30cabrio's Avatar
e30cabrio
I called Z1, told them what I was doing/what parts I was using and they ordered me a 97.5mm oem thickness Cometic gaskets for my 10k block/heads.
Thanks!
Old Feb 3, 2011 | 07:33 AM
  #1134
KA24DE's Avatar
KA24DE
Those cams sound mild for that displacement, and you're reducing your power potential by bringing down your rpm ceiling.
Old Feb 3, 2011 | 08:23 AM
  #1135
e30cabrio's Avatar
e30cabrio
But any more on the cams and I'll have driveability issues no? This is a daily.
The cams are what was recommended by BC (theirs)
As far as the rpm you mean the springs?
Thanks
Old Feb 3, 2011 | 09:03 AM
  #1136
Zazz93's Avatar
Zazz93
Thanks
I think what he is referring to, is he thinks your cam choice is too conservative. Personally I think the parts you mentioned will be ok and likely able to make decent power with a 7500 RPM redline. Becareful with the redline though, strokers don't like rev's as much as a OEM stroke. Higher piston speeds = trouble if pushed too far. And by using a more aggressive cam you will find yourself pushing the piston speed close to 24 m/s (which is race car like) to extract all the power available. As for springs thats a whole other thread, which wouldn't be a bad idea for your intended build up.
Old Feb 3, 2011 | 01:26 PM
  #1137
Nathan's Avatar
Nathan
The DE , Revup & Nismo pump are all the same pumps except for the vane
The DE was known to shatter at sustained high revs & was rectified when the revup was released.
The Nismo pumps uses a higher grade of steel in the vane & possibly different pressure spring than stock
Old Feb 3, 2011 | 08:12 PM
  #1138
tuko316's Avatar
tuko316
Awesome info. Thanks.
Old Feb 3, 2011 | 11:56 PM
  #1139
KA24DE's Avatar
KA24DE
Cams essentially become less aggressive with more displacement.
Old Mar 1, 2011 | 06:52 AM
  #1140
ETZ's Avatar
ETZ
Default Crawford headers
What's up Adam....do you know if the Crawford headers fit 06-08 Z's I remember reading that they didn't fit the 06-08 Z's because the steering linkage was changed that year. I called Crawford and who ever answered the phone said they fit,but some of the people at these company's answering the phones don't really know so I'm coming to the expert.
