New dyno numbers: 294 rwhp
Old Dec 10, 2007 | 04:35 PM
  #81
rocks's Avatar
rocks
I still need to get my cams tuned but I dont know if i will ever have the time to go to austin and get it tuned at uprev. My exhaust cams do wierd things past 5800 rpms so I am going to disable them in the ecu at 5800 rpms to redline. You guys know for an NA build you can use vq35hr pistons for like 11.5 compression and they are a decent price from nissan.
Old Dec 10, 2007 | 05:26 PM
  #82
rednezz's Avatar
rednezz
Originally Posted by TheJerk
Motordyne's 1/2 inch spacer, or Crawfords manifold would both net you more power in the higher rpm ranges.
As for the cam timing changes, was that only limited to 6600rpm on the mrev motor, compared to the Rev-up with VVT on intake and Exhaust sides, and a higher redline?
The guys at UpRev said the limitation was on the non-revup but I would assume that Rev-up would also be limited at 6600.
Old Mar 21, 2008 | 06:23 PM
  #83
kirradude1025's Avatar
kirradude1025
Pulleys? That would help...prob 8-10 hp
Old Mar 21, 2008 | 06:30 PM
  #84
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
Umm...
Old Mar 21, 2008 | 07:16 PM
  #85
doug's Avatar
doug
no
Old Mar 21, 2008 | 07:18 PM
  #86
BornSlippyZ's Avatar
BornSlippyZ
Originally Posted by SuperBlack350z
impressive numbers for n/a
Ditto.
Old Mar 22, 2008 | 12:19 AM
  #87
IntenseFab's Avatar
IntenseFab
Intense Motorsports
Originally Posted by rednezz
Well I took my car back to UpRev to retune after I pulled the intake standoff out of the motor. The car put down 294 rwhp. Much better but that is about all this motor is going to put down with my intake manifold. You can see the power the climbs strong to 6200 rpm then suddenly nose dives. Looks like its just not getting enough air flow. Hopefully the Cosworth manifold will solve this problem.
Any reason why you are running an N/A car excessively rich under WOT? 11.8 is quite a bit of fuel for no f/i. Tip in looks great but you are losing alot of power around 2100 RPM. Your graph should steadily increase and look alot less peaky.
Old Mar 22, 2008 | 08:05 AM
  #88
rednezz's Avatar
rednezz
My motor isn't balanced to run a lighter undampened pulley especially after reving it up to 7400 rpm.
Old Mar 22, 2008 | 08:10 AM
  #89
rednezz's Avatar
rednezz
Actually I just ran out of dyno time. I spent most of the dyno time tuning the cam advance instead of A/F ratio. I also had a bad coil pack and bad crank position sensor at the time and I wasn't aware of the problem. It made it very difficult to tune the car. I need to go back and retune the car...the power level of the car is significantly different after fixing the coil pack and crank sensor. I am dying to know what kinda of numbers I am putting down now.
Old Mar 22, 2008 | 08:21 AM
  #90
IntenseFab's Avatar
IntenseFab
Intense Motorsports
Awesome! Well from the sounds of things you'd hang Stillen/HKS S/C Equipped Z's
Old Mar 22, 2008 | 11:33 AM
  #91
dikspiel's Avatar
dikspiel
Chestons Toilet
turbonator should give you another 10hp...and those things that make your exhaust whistle are good for 2hp each
Old Mar 22, 2008 | 03:21 PM
  #92
rednezz's Avatar
rednezz
Don't know about that but the car is no slouch...been able to pull away on my friends EVO VIII that runs 110 mph in the 1/4 mile.
Old Mar 22, 2008 | 04:44 PM
  #93
ACEMAN's Avatar
ACEMAN
Master
Would love to see how you would do in the 1/4... My best mph with my mods is 108.5.. If i can pull that with out cams, you should have some nice numbers.
Get to the track
Todd
Old Mar 24, 2008 | 05:22 PM
  #94
DanielW's Avatar
DanielW
Actually I bet this would tear a stillen setup a new one... maybe even some ST setups running low boost. It should deffinitely run 12's
Old Mar 24, 2008 | 07:40 PM
  #95
IntenseFab's Avatar
IntenseFab
Intense Motorsports
I'm just trying to be PC and keep it cool with the Stillen HKS guys
Old Mar 24, 2008 | 07:44 PM
  #96
Nexx's Avatar
Nexx
rofl, poor stillen, hks guys.
Old Mar 25, 2008 | 10:23 PM
  #97
turismo's Avatar
turismo
Ahhh, just put a tornado in the intake tube.
Old Mar 26, 2008 | 06:17 AM
  #98
DanielW's Avatar
DanielW
are there any videos of this?
Old Mar 26, 2008 | 02:01 PM
  #99
c3 rolling's Avatar
c3 rolling
damn nice job, I would love to achieve your power N/A but the labor/downtime is fcking crazy in so cal for N/A jobs
Old Mar 26, 2008 | 07:22 PM
  #100
ct350z's Avatar
ct350z
i r jealous!!! i want big n/a powa!!!
