New dyno numbers: 294 rwhp
Old Mar 27, 2008 | 05:11 AM
  #101
WalkerT's Avatar
WalkerT
Professional
Get back to the dyno and get that thing tuned. I would love to see your track numbers. Let me know if you ever come up to Ennis I would love to run against you.
Old Mar 27, 2008 | 05:30 AM
  #102
rednezz's Avatar
rednezz
I just waiting for UpRev to get some time available on their dyno to finish tuning and get some current dyno numbers. I may go to the SAR this Friday but not 100% sure yet.
Old Mar 31, 2008 | 08:44 AM
  #103
BrazenZ's Avatar
BrazenZ
Originally Posted by IntenseFab
Awesome! Well from the sounds of things you'd hang Stillen/HKS S/C Equipped Z's
I don't think so. 305 rwhp/ 298 ft/lbs on a Dyno Dynamics loaded dyno with a torque curve that's flatter than Jessica Simpson's stomach
Old Mar 31, 2008 | 08:46 AM
  #104
RBlover69's Avatar
RBlover69
Originally Posted by BrazenZ
I don't think so. 305 rwhp/ 298 ft/lbs on a Dyno Dynamics loaded dyno.
but its still hella close.
Old Mar 31, 2008 | 08:53 AM
  #105
BrazenZ's Avatar
BrazenZ
Kudos on the build up Rednezz. I would point out ( and correct me if am wrong) but those are dynojet engine graphs which usually run a little higher than DynoDynamics
Old Mar 31, 2008 | 11:13 AM
  #106
rednezz's Avatar
rednezz
Yes dyno dynamics usually reads lower unless they are corrected to simulate dynojet numbers.
Old Mar 31, 2008 | 11:23 AM
  #107
Hella's Avatar
Hella
uh-oh somebody is getting touchy.........they were just joking.
or were they?
Old Mar 31, 2008 | 12:38 PM
  #108
mw9's Avatar
mw9
very nice, I have to read all of this later, at work.
Old Mar 31, 2008 | 01:24 PM
  #109
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Any reason why you are running an N/A car excessively rich under WOT? 11.8 is quite a bit of fuel for no f/i. Tip in looks great but you are losing alot of power around 2100 RPM. Your graph should steadily increase and look alot less peaky.
Mine also ran extremly rich for being stock. I am in Texas as well, 93 octane and here is my graph below. I think it has something to do with the HR.
Old Mar 31, 2008 | 05:55 PM
  #110
turismo's Avatar
turismo
agreed
Old Apr 8, 2008 | 08:22 AM
  #111
i8acobra's Avatar
i8acobra
STD correction = overinflated numbers. Switch to SAE for more accurate numbers.
Old May 18, 2008 | 03:43 PM
  #112
Nukiz0r's Avatar
Nukiz0r
Originally Posted by Nexx
wow, thats legit. i was almost fearing that you might be listing, popcharger, test pipes and nismo exhaust.
Old Jul 6, 2008 | 08:11 PM
  #113
Risky_Business's Avatar
Risky_Business
Quadrant 987c
Default Very....
impressive. My plan has always been to try to take the car as far as possible NA. My bolt on power mods are tne Nismo CAI, Nismo Exhaust, MD 5/16th Spacer, Nismo Headers, Berk Metallic HFCs. The plan is to pick up some AMS racing pullies, Nismo camshafts and tune w/ U-tec.
I'm not exactly sure where I'll end up but I really enjoy the pursuit of squeezing everything out possible.
Well done.
Old Jul 7, 2008 | 07:58 AM
  #114
Chef-J's Avatar
Chef-J
Booooosstt!!
I love this thread
Old Jul 7, 2008 | 08:03 AM
  #115
Alberto's Avatar
Alberto
Cranky FI Owner
NA, STD vs SAE is only a couple of hp difference. At the 600whp level it was less than 10whp difference in my car. Either correction is fine. Id rather see a STD correction than a NC #, then you have to ask what the weather was like, etc.
Old Jul 11, 2008 | 03:40 PM
  #116
NmexMAX's Avatar
NmexMAX
STD numbers are not always higher, it depends on ambient conditions, most namely, humidity. My STD numbers are typically LOWER than my SAE values. This is because I live in the desert, 8 -12% RH is common almost year 'round.
Lil' rundown on CF's:
Originally Posted by Maxima.org Dude
SAE (Society of Automotive Engineers), USA. Power is corrected to reference conditions of 29.23 InHg (99 kPa) of dry air and 77 F (25°C). This SAE standard requires a correction for friction torque. Friction torque can be determined by measurements on special motoring dynamometers (which is only practical in research environments) or can be estimated. When estimates must be used, the SAE standard uses a default Mechanical Efficiency (ME) value of 85%. This is approximately correct at peak torque but not at other engine operating speeds. Some dynamometer systems use the SAE correction factor for atmospheric conditions but do not take mechanical efficiency into consideration at all (i.e. they assume a ME of 100%).
STD or STP. Another power correction standard determined by the SAE. This standard has been stable for a long time and is widely used in the performance industry. Power is corrected to reference conditions of 29.92 InHg (103.3 kPa) of dry air and 60 F (15.5°C). Because the reference conditions include higher pressure and cooler air than the SAE standard, these corrected power numbers will always be about 4 % higher than the SAE power numbers. Friction torque is handled in the same way as in the SAE standard.
ECE (European Community), Europe. The ECE standard is based on the European Directives. Power is corrected to reference conditions of 99 kPa (29.23 InHg) of dry air and 25°C (77 F). Friction torque is not taken into consideration at all.
DIN (Deutsche Industrie Norm), Germany .
The DIN standard is determined by the German automotive industry. Power is corrected to reference conditions of 101.3 kPa (29.33 InHg) of dry air and 20°C (68 F). With the advent of European legislation and standards, national standards such as the DIN (formerly widely used) are now less significant.
Actual You may see this on some charts. What this means is this is the actual horsepower archived on the day tested and no correction factor has been applied. One can assume better or worse results with varying weather conditions.
Old Jul 31, 2008 | 10:13 PM
  #117
nismology1's Avatar
nismology1
Not sure if anyone else asked but, stock rods?
Old Aug 1, 2008 | 05:31 AM
  #118
rednezz's Avatar
rednezz
Sorry forgot to post that info. I'm using Eagle rods.
Old Aug 1, 2008 | 09:52 AM
  #119
Zquicksilver's Avatar
Zquicksilver
Originally Posted by Z1 Performance
Rednez - Was there any work done to the heads or were they used out of the box?
damn... i missed the fact that you had the cosworth heads
http://cosworthusa.com/store/pc/view...7&idproduct=69
(related)cool article...
http://www.sportcompactcarweb.com/te...ild/index.html
Zquicksilver
Old Aug 1, 2008 | 12:03 PM
  #120
rednezz's Avatar
rednezz
Looks like the headers on the Cosworth motor look very similiar to the Nismo headers. My problem is the intake manifold. After 6300 rpm I just don't have enough air. I really wish I had a Cosworth intake manifold or anything better than I have now so I can take full advantage of my heads and cams. I'm sure I can pick up another 10+ rwhp.
