Hypothetical v12 question?
Old May 31, 2008 | 03:57 PM
bimmertech's Avatar
bimmertech
check into the hyabusa V8. they took 2 4 cyl's and made a V8.
anything i possible with enough money, my guess though is when he is done he could have just bought a V12 lambo instead of having a kit car with some 1 off engine.
as for ecm, just do like most oe V12's and use 2. run 2 seperate mafs, etc. basically electronically you have 2 seperate V6's. its wild to drive a V12 with only 6 cylinders firing, bmw will shut down an entire bank if the secondary dme has failsafe faults.
Old Jun 2, 2008 | 05:16 AM
Highway Riding's Avatar
Highway Riding
Interesting thanks for the info..
Old Jun 2, 2008 | 01:21 PM
mdracer76's Avatar
mdracer76
Lots of neigh-sayers in this thread.
It can be done.. but it wont be cheap.
the VQ35 is an aluminum block. Alum. is difficult to weld (not as east as Iron)
Any standalone worth its salt can operate 12 cyl.
You can not just weld a crank together. You will need to mock the 2 cranks, and have a new crank made.
You'll also have to consider block cooling, etc etc etc..
If you have the money (and LOTS of it in this case) anything is possible. It would be cheaper to find a v12.
Old Jun 2, 2008 | 08:47 PM
turismo's Avatar
turismo
Originally Posted by DelayedZ
Aren't altimas fwd, why not put one in the front and one in the rear of this lambo kit car, I saw a hyundai do it before, had a motor in the front and in the trunk made it awd...
I remember that article. It was in SportsCompactCar shootout a few years back
Old Jun 3, 2008 | 08:55 AM
Highway Riding
I can only imagine how much a custom crank would cost...
again thx all opinions and or suggestions are greatly welcomed...
Old Jun 4, 2008 | 02:43 AM
350zna's Avatar
350zna
Well i know the top secret v12 supra is a Toyota Century motor? Whatever that is, but interestingly they are using 2 Fcon pros since they only go up to 8 cylinders they use one for each bank, as they explain on their video.
Old Jun 10, 2008 | 08:13 PM
T_K's Avatar
T_K
The cost wouldn't be much less than building a V12 from scratch.
TK
Old Jun 11, 2008 | 11:33 AM
h2kSPiG's Avatar
h2kSPiG
You would be better off starting with an inline 6 since you could use two of the heads. Pretty much the same idea as the hayabusa V8. http://www.h1v8.com
If you look at what he had to do just to make it work right, you can start to see what would be involved in this. I would rather the lightweight V8 than the incredibly long V12 anyway.
Old Jun 24, 2008 | 10:45 AM
GTM's Avatar
GTM
Vendor - Former Vendor
Just get a V12 out of a mid to late 90s BMW 750iL, cheaper, and will actually work.
Old Jun 24, 2008 | 11:04 AM
Mr.'s Avatar
Mr.
Tell your friend to get the v12 from a Jag XJS.
http://en.wikipedia.org/wiki/Jaguar_V12_engine
Probably cheaper than the alternatives.
Old Jun 24, 2008 | 07:25 PM
Highway Riding
Thx for the replies again. He just bought a lift for his garage so this car is gonna under some sort of surgery sooner than later. Hopefully i'll try to follow up with some pix.
Old Jul 11, 2008 | 01:37 PM
vnarang's Avatar
vnarang
copy and paste the engines together.
Old Jul 19, 2008 | 11:38 AM
irax's Avatar
irax
just tell your friend to look into the Peugeot 907 technology.
http://en.wikipedia.org/wiki/Peugeot_907
2 3.0 v6 engines working together. so its entirely possible.
Old Jul 19, 2008 | 11:45 AM
BornSlippyZ's Avatar
BornSlippyZ
Originally Posted by Hoooper
its always possible to combine two engines, drag racers used to do it a lot. whether or not theres even a reason to do what he wants is a whole nother thing. why doesnt he get a wrecked m5 v10 instead?
Or an older V-12 from a BMW like with the Ultima kit car...What the Op's friend wants is a pretty good head ache, unless you have good machining skills/welding/CnC expertise...just my 2 cents
EDIT: George beat me too it!
Old Jul 21, 2008 | 04:20 PM
R-TuneZ's Avatar
R-TuneZ
it is actually a really interesting concept and it has been done before, one engine in the front and one in the back, in a delorean, i believe. however setting up the tb's to work in a seamlessly joint manner, as well as the whole differential setup issue is what makes this an impossible setup. you would have to control the output of both engines, which also means controlling the intake charge temps and afr ratios, and they would have to be exactly the same otherwise you would get erratic behavior. let me see if i can source it.
ok yea apparently this guy was successful, though its a questionable design lol.
link...
http://www.gendreaumicro.com/tenpointtwo/11472index.htm
it has two different modes, an independent fwd mode, powered by a 2.0 prelude engine, and a 4wd mode, where the rear engine is a 500 cubic inch caddie motor. the transmissions are setup to shift seamlessly and the rear auxiliary engine is controlled from within the cabin. the engines run independently with different differentials. considering the rear engine creates a lot more torque then the front, i am assuming it is impossible to achieve any sort of practicality with it, much less any sort of performance.
Old Jul 21, 2008 | 04:45 PM
350Zenophile's Avatar
350Zenophile
Default bimoto 800hp audi tt
http://www.youtube.com/watch?v=W0kN_4YdhsI
Old Jul 23, 2008 | 03:10 PM
zroadster123's Avatar
zroadster123
isnt combining 2 6 cyls called a w12 instead of a v12? like in the bently continental gt its a twin turbo w12 so its pretty much 2 single turboed 6 cyls put together and in the veyron its a w16 so its 2 twin turbo v8s put together am i right?
Old Jul 23, 2008 | 03:19 PM
  #38
Hoooper's Avatar
Hoooper
not a w unless you combine them in a w shape. im thinking he was suggesting a back to back configuration AKA v12
Old Jul 30, 2008 | 06:10 AM
  #39
Netko350Z's Avatar
Netko350Z
By the time he is done, the price tag will be close enough that he could have just bought a REAL Lambo.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
