Cosworth 3.8L VQ generates 438hp NA
Old Jan 20, 2009 | 10:33 AM
  #41
gothchick's Avatar
gothchick
Oh gawd. The pwnage~ Turbo timer on NA build... Why do I even bother logging in sometimes? Lol.
Old Jan 20, 2009 | 06:00 PM
  #42
jmccarty's Avatar
jmccarty
Turbo timer is a freebie from the shop and serves a function in a tropical environment. Also if you look into the spec, it times your 0-100kmh, 1/4 mile and several other functions. When I turn the key off after 6 laps at the track and leave the car, the engine will continue to run until oil and water temp are down to set levels. Turbo or not, it serves a function.
The drive train? I'm not testing hp at the crank and would hope not to get any slip on the dyno, but helps to realize how the dyno results may transfer to the street in action. I could edit the absolute non-essential info out for those offended by a long list?
Old Feb 4, 2009 | 02:40 PM
  #43
warmmilk's Avatar
warmmilk
Originally Posted by jmccarty
Ok, here's the total list since I can't link to ********* forum:
1 Cosworth VQ35 CNC Big Valve Cylinder Head "Rev Up Version"
2 Cosworth VQ35 High Performance 95.5mm Short Block 3.5L
3 HKS F-Con Vpro Engine Management Unit
4 HKS Valcon VCAM Plus Kit
5 Cosworth Metal Head Gasket 96mm
6 Cosworth Head Studs Kit VQ35
7 Exedy Hyper Series Carbon Twin Clutch Kit
8 Cosworth Twin Intake Plenum
9 HKS Stainless Exhaust Manifold System
10 Mine's Straight Pipe Kit
11 HKS Front Center Pipe
12 HKS Twin Power Ignition System
13 Cosworth High Volume Fuel Rail Kit
14 HKS Kansai Intank Fuel Pump with Relay Kit
15 Nismo GT Pro LSD 1.5 Way
16 Nissan OEM Bearings and misc.
17 Kakimoto Racing Dual Exhaust
18 HKS Hypermax III Sport suspension
AND ADDED DURING THE BUILD
19 HKS Fire Racing Plugs M35iL
20 HKS 480cc injectors
21 Arc Full Aluminum Radiator
22 HKS Oil Cooler Kit
23 HKS DB RS oil Temp, Oil Pressure, Water Temp and unit controller
24 Carbing oil collector tank 10mm
25 Carbing Aluminum Front Strut Bar With M/CS
26 HKS Turbo Timer Black Limited (Type-1)
27 C's Short Shifter Kit w/Nismo GT Titanium Shift ****
28 Carbing Radiator Cooling Plate
29 Varis Air Duct (ordered)
the original article said that the headers were custom built by cosworth, not an hks piece
whats a "front center pipe"?
Old Feb 4, 2009 | 03:06 PM
  #44
Kwame's Avatar
Kwame
That is the list of components for his own personal build that just so happens to consist of some Cosworth parts.
A Front Center Pipe is the same thing as a "Y-Pipe."
Old Feb 4, 2009 | 08:12 PM
  #45
jmccarty's Avatar
jmccarty
Thanks Kwame, ditto that! This Cosworth short block has been assembled/built by the Singapore branch of HKS Technical Factory http://www.hks-garager.com.sg
I am still waiting on delivery of the Cosworth Intake Plenum before tuning and dyno test which will be posted here.
Old Feb 5, 2009 | 07:30 AM
  #46
warmmilk's Avatar
warmmilk
ah i c, i thought you were talking about the scc engine...
Old Feb 5, 2009 | 07:48 PM
  #47
jmccarty's Avatar
jmccarty
I hope to get somewhere near the scc build but will be limited by discplacement so if I can get near to 400 will be very pleased. Near means over 300 WHP!
Old Feb 8, 2009 | 03:05 PM
  #48
UnFairLady Z's Avatar
UnFairLady Z
so what ever happened to this motor?
Old Feb 8, 2009 | 05:38 PM
  #49
Nathan's Avatar
Nathan
As you are using the HKS Valcon camshafts which only have modest lift (10.5mm) & only
264 deg of duration you are not going to get anywhere near 400.
Old Feb 8, 2009 | 06:07 PM
  #50
jmccarty's Avatar
jmccarty
If not, what a waste of $2,400 for variable timing control! I'll be looking for Nismo Spec 2 cams if the HKS cams prove to be disappointing.
UnfairLadyZ, I emailed Eric Hsu at Cosworth for final numbers just before they were announced in SCC magazine but did not get a reply. My engine will finally be tuned, with or without the long awaited Cosworth twin plenum manifold on the 16th of this month. My tuner will take 2 or 3 days to complete the job and will go over it again when (and if) the plenum shows up. I have also orderd the Kinetix SSV manifold and will test them both.
Old Mar 30, 2009 | 06:41 AM
  #51
jmccarty's Avatar
jmccarty
Default 401/321 - awesome!!
It is done, I will scan it in the morning.
401.7hp at the fly wheel @7670rpm
321.3whp @7687rpm
329.7 lb/ft fly wheel torque @4954rpm
263.7 lb/ft rwt @4970rpm (I will need to check this, it is reading by a factor x final drive on the print out)
Dynapack Chassis Dynamometer
Fuel: HKS Drag Racing Fuel
95 degrees F.
>90% humidity
Scan will follow tomorrow when I get to the office.
Tuned by Lester Wong - HKS Technical Factory Singapore.
Old Mar 30, 2009 | 07:16 AM
  #52
discom's Avatar
discom
321.3whp @7687rpm
95 degrees F.
>90% humidity
Finally tracked you down. Was great meeting you at Garage R earlier this evening.
Wonder if there are anymore my350Z members in Singapore.
Anyways...nice car and nice dyno graph...still can't get over the pig tail in the graph...you better explain how that happened when you post the dyno graph up
Old Mar 30, 2009 | 07:27 AM
  #53
0jiggy0's Avatar
0jiggy0
nice Work
Old Mar 30, 2009 | 07:33 AM
  #54
jmccarty's Avatar
jmccarty
Cheers Discom! It's the friction brake engaging.
You will see it up in the morning.
Nice to meet you too.
Old Mar 30, 2009 | 07:39 AM
  #55
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Good torque #'s and right where it should be power wise given the mods
I'm sure the race gas helped given the temp and humidity too, so good stuff - what were the pump gas #'s?
Old Mar 30, 2009 | 07:45 AM
  #56
jmccarty's Avatar
jmccarty
We used 100% HKS Drag Racing Fuel. They don't actaully publish the numbers. I'll ask again tomorrow at the shop and photograph the 20litre cans it comes in. I was going to go with VP MS109 but the supplier ran out so went the extra on the HKS fuel to finally get the tune and dyno done. I'll let you know what HKS will let me know.
Old Mar 30, 2009 | 04:12 PM
  #57
jmccarty's Avatar
jmccarty
Default 401bhp/321whp
Here they are!
The torque wheel power is calculated by the lb/ft scale/the ratio (which is 3.9 final drive + 2 for the dyno drive so 1,556/5.9 = 263.7 lb/ft)
The date on the file is not correct. It was done last night (30 March 09).
Attached Thumbnails Cosworth 3.8L VQ generates 438hp NA-dyno-bhp-800x600.jpg   Cosworth 3.8L VQ generates 438hp NA-dyno-fhp-800x600.jpg
Old Mar 30, 2009 | 04:16 PM
  #58
jmccarty's Avatar
jmccarty
Here is the setting up.
Attached Thumbnails Cosworth 3.8L VQ generates 438hp NA-setting-the-dyno-up.jpg   Cosworth 3.8L VQ generates 438hp NA-r-left-wheel.jpg   Cosworth 3.8L VQ generates 438hp NA-r-right-wheel.jpg
Old Mar 31, 2009 | 03:56 AM
  #59
jmccarty's Avatar
jmccarty
Z1 - All I can get is 110 from a spec sheet in Japanese. The can does not say and the spec sheet is in Japanese and only has one rating.
Old Mar 31, 2009 | 05:29 AM
  #60
Z1 Performance
Former Sponsor
did you do any dyno runs on just normal fuel, or only the HKS race fuel? Just curious
enjoy the car!
