My NASA Racecar NA Build
Old Jun 9, 2012 | 01:42 AM
  #421
S13 S1lvia's Avatar
S13 S1lvia
This is an awesome thread, easily spent the past hour an a half reading this and i can't understand why people publish books anymore. Only thing i'd object to is that ugly splitter i personally would've gone with a foam/fiberglass one but hey thats just me. That spoiler you're running is just awesome!
Old Jun 9, 2012 | 02:00 AM
  #422
terrasmak's Avatar
Originally Posted by sfarrah
I have gutted a lot of my stock hatch and added lexan to reduce weight as much as possible although a composite hatch would surely reduce weight even further. If I purchased a stock style hatch swapping components wouldn't be too much work. I'd have to redo all of the mounting if I went with the Asuka style hatch with the duck tail lip built in.
Lexan back window, what thickness did you use, and how many straps? I'm looking at doing my back 3 windows in the next few weeks. Also did it flex enough or did you have to heat it up and form it?
My thoughts are 2 aluminum, 1/2 inch 90 degree straps running on the inside of the window bolted in just at the ends of the 3rd brake light. Then i was thinking rivets every 4 inches in window to the strap and sheet metal screws every 4 inches around the outside.
I could be overthinking all of this.
Was also thinking about cutting 4x , 3 inch holes in the window to bleed off high pressure from the interior.
Old Jun 9, 2012 | 05:56 AM
  #423
03threefiftyz's Avatar
03threefiftyz
What series do you run in Terra? Pretty sure SCCA requires at least 1/8" thickness for lexan.
Old Jun 9, 2012 | 06:17 AM
  #424
laze1's Avatar
laze1
Me
Originally Posted by Sonic1
Congrats on the PTA Championship! I have a long way to go with the car.
Anyone planning on running the new SPEC class? Seems like a good money maker for Nissan. It would cost thousands to make your car slower. I like the concept of a Z class. Maybe down the road.......
Old Jun 9, 2012 | 08:07 AM
  #425
terrasmak's Avatar
NASA TT , hopefully make one or two events this year. Then PTB next year is the goal.
Old Jun 9, 2012 | 02:23 PM
  #426
sfarrah's Avatar
sfarrah
I got the kit from LSAuto.com a number of years ago. Can't remember the thickness and I don't see it listed on their webpage anymore. It came with hardware and is bolted in with 24 small nuts and bolts. I don't use any straps and haven't had any problems with it so far.
It's a pretty flat piece that doesn't require any bending/molding. Should be fairly easy to cut your own.
Old Jun 9, 2012 | 02:26 PM
  #427
03threefiftyz
With remote shocks, bolt-ons, aero, etc you are going to be very hard pressed to stay in TT/PTB. Keep in mind, you want to be on A6's or R1S's to be competitive. 225 A6> 255 R6.
Old Jun 9, 2012 | 02:28 PM
  #428
sfarrah's Avatar
sfarrah
A foam/FG/CF splitter would never withstand the abuse that the Fulcrum piece can. I've gone off track more times than I can count and the only repairs I have ever had to do was replacing a couple rivets. It is a highly functional and very tough splitter. It even comes with wear plates for the bottom that can easily be replaced.
Old Jun 9, 2012 | 04:10 PM
  #429
S13 S1lvia's Avatar
S13 S1lvia
If that's the case then i might have to take that back, doesn't appear as something that would be that durable.
Does the leading edge not take a hammering though?
Old Jun 10, 2012 | 05:15 PM
  #430
SE5spd's Avatar
SE5spd
Do you guys use custom splitters?
Old Jun 10, 2012 | 05:43 PM
  #431
03threefiftyz
You can make your own, or use something like the fulcrum or others.
Old Aug 2, 2012 | 04:19 AM
  #432
KingBaby's Avatar
KingBaby
Hardest Setting
Any updates
Old Aug 2, 2012 | 05:24 AM
  #433
mw9's Avatar
mw9
When you get a chance maybe put some pics up?
Old Mar 26, 2013 | 05:30 PM
  #434
MonkeyMagic72's Avatar
MonkeyMagic72
Forget about daily driving and turbo my 350Z. I am going to build for track and NA only. Awesome thread
Old Mar 31, 2014 | 12:28 PM
  #435
ThreeFiveZero Z's Avatar
ThreeFiveZero Z
Haven't had an update in a while. Last year life got in the way, so I didn't get out to the track as often as I would of liked. The season started this past weekend at Sebring, and unfortunately what appears to be a leaky valve cover ended our race weekend shortly after qualifying Saturday. I was getting some smoke in the cabin, and had some oil dripping from the back of the engine. The driver side valve cover is pretty gritty and dirty compared to the passenger side, so I am going to be pulling this in the next few weeks. I am signed up to instruct with Chin at Sebring in 4 weeks, so I need to get started soon!
From a longer term view, I am starting to contemplate the next step for the overall car. The car is currently classes in ST3, but I am allowed to have 350whp for my current weight of 3200 w/ driver. I have some weight reduction plans as well, but I can't see really getting the car any lighter than 3075-3100lbs. I am thinking about either going with a 3.8L stroker or the HKS s/c kit that sfarrah has been running. This isn't happening anytime soon as my current build is still very fresh.
Old Apr 3, 2014 | 06:10 AM
  #436
03threefiftyz
It really should not be terrible difficult to get to 3050 w/cage IMO.
Old Apr 3, 2014 | 09:36 AM
  #437
scotts300's Avatar
scotts300
Agreed. Most of the west coast SpecZs are in the 2950-2980 range dry with cage.
Old Sep 8, 2016 | 10:22 AM
  #438
ThreeFiveZero Z
So this is my final post in this thread/journey. We converted the car to Spec Z early this year, and it's for sale. https://my350z.com/forum/zs-and-gs-f...z-racecar.html. Planning to get into something cheaper and with car counts, it's looking like Spec E30. Hoping to get another Zed for the street in the intermediate future.
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
