Tomei Header and Cam install
Old Sep 23, 2009 | 10:14 AM
  #321
gabe3d's Avatar
gabe3d
Those numbers are OD measurements.
Old Sep 23, 2009 | 11:00 AM
  #322
allmotorsedan's Avatar
allmotorsedan
Thanks Gabe!!
Old Sep 27, 2009 | 03:22 AM
  #323
_ink's Avatar
_ink
sorry to Hijack the thread Gabe, but i've reconsidered my build due to how expensive it is in Australia to have these installed.
I have the exact same Tomei cams as Gabe and they are Brand new in the box, with original certificates included.
Please PM me if you are interested.
For Sale thread is here:
https://my350z.com/forum/engine/4579...n-ex-cams.html
Old May 11, 2011 | 10:43 AM
  #324
VQpwr03z's Avatar
VQpwr03z
Gabe here is my dyno results from this past saturday.
current mods:
tomei cams 264-10.5 lift
tomei valve springs
tomei headers V2
tomei test pipes
XYZ motordyne Y pipe
Greddy TI C single
JWT pop charger
custom intake manifold
I lost about 12-15whp in the midrange. im going back to the stock manifold.
File Type: pdf
Old May 11, 2011 | 06:15 PM
  #325
kacz07's Avatar
kacz07
^Nice power.
Old May 11, 2011 | 06:48 PM
  #326
gabe3d's Avatar
gabe3d
current mods:
tomei valve springs
tomei headers V2
tomei test pipes
Greddy TI C single
JWT pop charger
Is the only difference between the two dynos the Tomei components? No tune either?
Old May 12, 2011 | 04:56 AM
  #327
VQpwr03z's Avatar
VQpwr03z
yea the tomei components. No the car was tuned before i retuned when i installed the tomei components.
Old May 12, 2011 | 05:00 AM
  #328
VQpwr03z's Avatar
VQpwr03z
Originally Posted by kacz07
^Nice power.
Thanks but im still a lil disapointent with the results.
Old May 12, 2011 | 05:31 AM
  #329
gabe3d's Avatar
gabe3d
Looks like you gained a solid 20tq throughout almost the eintire revband. Run 2 is the latest one, doesn't seem like you lost anything anywhere other than the really top end which maybe he let go on the throttle.
Did you have stock cats and stock headers prior to this? Interested in your custom intake manifold. You got any pics?
Old May 12, 2011 | 06:48 AM
  #330
VQpwr03z's Avatar
VQpwr03z
Gabe the run on top is when i only had full exhaust and the manifold, the run below is when i installed the tomei components, which mean i lost, maybe u missunderstood. u were looking at the first run thats when i gained tq about a year ago. i will post a pic of the manifold. i had stock headers prior to this, but i had berk test pipes.
Old May 12, 2011 | 06:55 AM
  #331
VQpwr03z's Avatar
VQpwr03z
Here is a pic of the manifold. there only a few of this on 350z's.
Old May 12, 2011 | 07:09 AM
  #332
gabe3d's Avatar
gabe3d
I see, the dates are misleading since there is no year. It would appear that run2 would be the latest run but doesn't seem like the case as you are indicating.
run1: 05/07 273whp/221wtq
run2: 06/08 272whp/231wtq
Since that is the case, then I would agree with you that those numbers are very dissapointing. What were you running prior to the Tomei V2 Headers and TPs?
Thanks for the pic. Were there any modifications to the lower plenum?
Old May 12, 2011 | 07:51 AM
  #333
VQpwr03z's Avatar
VQpwr03z
I was running stock headers. The modifications to the lower plenum were the same as the Mrev2 from motordyne. Im sorry for the question still a newbie. What TP stand for?
Old May 12, 2011 | 08:10 AM
  #334
2004Black350z's Avatar
2004Black350z
Exhaust Whore
test pipe
Old May 12, 2011 | 08:31 AM
  #335
VQpwr03z's Avatar
VQpwr03z
Originally Posted by 2004Black350z
test pipe
thanks i feel like an idiot.
Old May 12, 2011 | 09:45 AM
  #336
VQpwr03z's Avatar
VQpwr03z
Gabe i was running stock headers & berk test pipes.
Old May 29, 2011 | 06:12 PM
  #337
denchan350gt's Avatar
denchan350gt
current mods:
tomei valve springs
tomei headers V2
tomei test pipes
Greddy TI C single
JWT pop charger
put the stock top back on. I think there is too much volume with the modified lower and top.
I have the same intake manifold (DM2) on my G35 I only showed gains putting the stock top back on for some reason. The numbers were the same as with a spacer, but with the stock top on I gained.
The only thing is you have to jb weld the 6 holes in the stock top to prevent leaks due to the lower plenum holes being filled.
Give it a try before replacing both parts or headers. I have headers also.
Old May 29, 2011 | 08:34 PM
  #338
350z-Na's Avatar
350z-Na
Hey Gabe, i was reading some of your post in the beginning of this thread and you said that heat wrapping your exhaust system reduces rasp and drone. I have the agency power exhaust and i will be getting test pipes and a y pipe soon. If it reduces rasp and drone then i'm going to heat wrap everything. Was it a big difference in noise?
Old May 31, 2011 | 08:58 AM
  #339
gabe3d's Avatar
gabe3d
It was audibly different but not a dramatic one. There aren't any scientific study behind this but, we do know that hot air moves faster, wrapping does alter sound frequency and perhaps all of those enables resonance cancellation to work better in my exhaust setup. I do have resonated test pipes as well as muffled axle backs.
Old Jun 3, 2011 | 09:41 PM
  #340
bikinilust's Avatar
bikinilust
might just be the same idea as Dynamat for sound systems...
its kind of adding "load mass" to the exhaust tubing, thus reducing resonance.
