Pistons
Old Jun 26, 2009 | 02:33 AM
pipni's Avatar
pipni
Default Pistons
Hello,
i need pistons with standart compression 10.3:1 and 96.0mm. I found only cosworth PA2688+050 . Does it make another one? Thanks.
Old Jun 27, 2009 | 12:34 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Petr - that part # is not stock compression, it is 11:1. Cosworth only makes 8.8:1 and 11:1
I am not aware of any manufacturer that offers a stock compression piston as an "off the shelf" item, though most manufacturers (Wiesco, CP, JE, etc) will make any compression you want as a special order
Old Jun 27, 2009 | 01:33 PM
pipni's Avatar
pipni
Hi Adam,
i found these items from Coswort :
PA2688 - 95,5 mm - 10,3 : 1
PA2688+050 - 96,0 mm - 10,3 : 1
PA2687 - 95,5 mm - 8,8 : 1
PA2687+050 - 96,0 mm - 8,8 : 1
2002036 - 95,5 mm - 11,0 : 1
2002038 - 96,0 mm - 11,0 : 1
Does Coswort make it with 10,3:1 or no?
How long is delivery delay of custom pistons from CP or Wiseco?
Thanks
Old Jun 27, 2009 | 02:55 PM
Z1 Performance
Former Sponsor
those part #'s no longer exist in the Cosworth catalog - I can double check Monday if you like
custom pistons usually take about 8 weeks....however, they can speed up the process for higher costs, which vary by manufacturer
Old Jun 29, 2009 | 03:00 AM
pipni's Avatar
pipni
Please check it. I found it only on www.mynismo.com .
Old Jul 8, 2009 | 01:15 PM
Swimminggerman's Avatar
Swimminggerman
Wiesco will make custom for you for around $600.
seagrasser
Oct 11, 2015 03:27 PM
B Esquire
Sep 24, 2015 07:52 AM
hardkicks
Sep 20, 2015 12:28 PM
