NA Build: Kacz07's 2006 SS 350z RevUP
Old Jun 20, 2011 | 07:50 AM
  #421
gabe3d's Avatar
gabe3d
Nice vid and sound is very crisp. How does it sound at idle?
By the way, how are you liking your willwoood compared to your brembos?
Good and bad thing about cars is that there is always something to tinker with. It keeps the blood flowing in our veins. Keep up the good work!
Old Jun 20, 2011 | 11:56 AM
  #422
2004Black350z's Avatar
2004Black350z
Exhaust Whore
awaiting fly by vid...................
Old Jun 20, 2011 | 01:25 PM
  #423
mgrotel's Avatar
mgrotel
Originally Posted by kacz07
I run the Ferrea valvetrain that IPP offers in their engine packages. I spoke to JWT and Ferrea before i built the engine and JWT recommended I used their valve springs because they optimized their springs with their cams. Ferrea said their springs were stronger, so they should hold up fine, but I will definitely revisit this inquiry.
I'm going to call IPP and Ferrea and ask them about safe rpm limits for the valvetrain/motor. Cams are still a ways off in the future, but it will pay dividends to have this info out there before I make my next move.
of course jwt will say use their springs, they want to sell their product. i had the same discussion with BC. but in talking with someone experienced with building and working these heads, i came to the conclusion that the small extra cost of dual valve springs was well worth it for what i would be doing with the car. i would just hate to see you get into trouble with valve float because you wanted an extra 200 rpm than your springs can't handle.
and also came to find out there are only a couple places in the world that actually make the cams, so saying to a customer that their springs are made for the cams really doesnt hold a lot of weight in my mind, since all brands pretty much come from the same build shop, but this is imo too
Old Jun 20, 2011 | 01:30 PM
  #424
mgrotel's Avatar
mgrotel
Originally Posted by e30cabrio
How about JWT S7 cams & JWT springs? What would you say the safe rpm limit with a BC 88mm crank, BC rods & 11.0.1 JE pistons would be?
with the longer stroke, you need to consider piston speeds at high rpm. combine that with no oil squirters and i would be very cautious to go much higher than stock. because even if you keep the same rpm limit as stock, you will have higher piston speeds because of the longer stroke. just dont ruin your engine trying to get some extra rpms, imo
Old Jun 20, 2011 | 04:41 PM
  #425
MM'08_350Z's Avatar
Love the video!!! I love High pitched 350Z exhaust sounds.
Old Jun 20, 2011 | 05:08 PM
  #426
Zazz93's Avatar
Zazz93
mgrotel, I think you have to go with track records... I'm not disputing the fact that a dual spring setup can potentially support higher revs but I think its pretty clear JWT springs can support most rev limits the VQ can turn. If you get crazy with the limiter, dual springs or not, revs can and likely will kill your engine.
Also you don't want to over-spring the engine either, especially with the labor intensive valvetrain the VQ has.
Old Jun 20, 2011 | 06:19 PM
  #427
mgrotel's Avatar
mgrotel
I know what you're saying, I just decided to stick to the advice of someone with tons of vq head experience, and with many high HP builds under their belt. There was a thread here somewhere where a single spring motor had valve float over 8000rpm, but I don't remember the exact thread. They had to rebuild the entire motor, I'll see if I can find it. I'd rather be over sprung than under sprung, if "sprung" is even a word in that context, lol
Old Jun 20, 2011 | 07:07 PM
  #428
the_coupe's Avatar
the_coupe
unless you're t-pain! lol i keed i keed
judging by the specs....the bc springs are stiffer than the jwt springs. but i got a hella good deal on my cams/springs/retainers which is why i went with all BC valvetrain. my guess...once i get it tuned and dyno'd.....we'll see where my powerband starts to drop and ill set my rev limit just above that......no point in rev'n out higher than what the power runs up to.
Old Jun 21, 2011 | 11:01 AM
  #429
kacz07's Avatar
kacz07
Originally Posted by Erik@R/Ttuning
Keep on keepin' on with this killer Z Jon.
Thanks, Erik. I will be seeing you guys soon. Hope all is well over there!
Old Jun 21, 2011 | 12:16 PM
  #430
mgrotel's Avatar
mgrotel
unless the power dropoff after peak power falls of less dramatically than it does right before peak power.
for example, say peak is at 7500rpm with 300hp, 7200rpm has 280hp, and 7800rpm has 290hp. would you rather shift at peak and take the steeper power dropoff, or hold till 7800 and then absorb less of that pre-peak dropoff since you wont fall as short in the rpm range because of the later shift? which one has the higher area under the curve? area under the curve is much more important to me than peak power is anyway.
Old Jun 21, 2011 | 07:26 PM
  #431
the_coupe's Avatar
the_coupe
true.....i was meaning as when the power is done done. im hoping mine will hold out to 7800
Old Jun 27, 2011 | 05:47 PM
  #432
jmccarty's Avatar
jmccarty
My Cosworth engine, Cosworth heads and internals (some HKS) is rev limited to 8,600rpm and has worked fine with no issues since March 2009. Look up my build thread or profile if you want to see what can be done to an N/A VQ35 engine.
Old Jun 27, 2011 | 08:07 PM
  #433
mgrotel's Avatar
mgrotel
very nice, im sure ive read your build at some point or another, do you make power that high?
Old Jun 27, 2011 | 08:25 PM
  #434
2004Black350z
Exhaust Whore
curious huge build like that with no thread vids dyno sheet?
Old Jul 4, 2011 | 04:09 PM
  #435
jmccarty's Avatar
jmccarty
Search my name and you will find the thread.
Old Jul 4, 2011 | 07:18 PM
  #436
2004Black350z
Exhaust Whore
i see no dyno sheets piks vids etc so dont mean sh** to me.
Back OT
Kacs wheres the flybys?
Old Jul 4, 2011 | 07:55 PM
  #437
the_coupe's Avatar
the_coupe
garsh, i gotta do some fly-bys...but my car sounds like something from a drift comp! lol
Old Jul 4, 2011 | 08:03 PM
  #438
kacz07's Avatar
kacz07
2004, i posted jmccarty's dynos earlier in my this thread. As for the fly-bys, dude is working on fixing my bodykit. I'm going to Cali to visit a grad school, so I'll be away for a bit.
Coupe, post 'em up!
Old Jul 4, 2011 | 09:39 PM
  #439
2004Black350z
Exhaust Whore
daaammmmiiittt
Old Jul 5, 2011 | 12:33 AM
  #440
gabe3d's Avatar
gabe3d
Coupe, post 'em up!
If you are around the bay area then let me know, we can go golfing and do some car talk. Which school are you visiting btw?
