NA Build: Kacz07's 2006 SS 350z RevUP
Old 06-30-2012, 08:41 AM
  #481
e30cabrio
e30cabrio's Avatar
Received 2,600 Likes on 2,056 Posts
Wow, sorry about the cam that freaking sucks although you were really lucky no other real damage was done.
Which cams do you have? Are those injectors P&P? Did you need any supporting mods for them?
Old 07-22-2012, 12:14 PM
  #482
kacz07
kacz07's Avatar
Jwt C8R cams
Injectors are PnP
Haven't installed yet
Getting rid of nitrous
Interested in dry sump
Anyone need a Cosworth manifold?
Old 07-22-2012, 06:01 PM
  #483
Classy
Classy's Avatar
Dry sump eh? What are going for here? And no more nitrous!
Old 07-23-2012, 06:20 AM
  #484
BoomerZ33
BoomerZ33's Avatar
Originally Posted by kacz07
Jwt C8R cams
Injectors are PnP
how much you selling it for Jon?
Old 07-23-2012, 08:17 AM
  #485
graffkid732
graffkid732's Avatar
Pm me more info on the nitrous setup
Old 07-23-2012, 12:09 PM
  #486
kacz07
kacz07's Avatar
Sent you a MSG through FB. FYI, it's the CF end caps, but I think you know this.
Old 07-23-2012, 12:34 PM
  #487
kacz07
kacz07's Avatar
Msg'd on FB, too. Never been used.
Old 09-03-2012, 01:52 PM
  #488
kacz07
kacz07's Avatar
Cooling is obviously a big consideration on an engine that can run hot. For those interested, I have taken out the OEM engine bay trim in favor of a low profile engine bay trim that just covers the metal guides.
I used this on my TT after viewing data showing engine bay temp decreases of 18 deg F! It protects the engine bay from weather still, allows the hot air to escape, and makes the growl a little louder, too.
Old 11-08-2012, 12:50 PM
  #489
kacz07
kacz07's Avatar
Just picked up:
Wheels:
Enkei Raijin
18x9.5 +15 on all 4 corners
Advan T7
19x9 +22 in front, 19x10 +25 in back
Suspension:
Cusco sways
SPL end links
Getting rid of some quality parts:
https://my350z.com/forum/north-east-...gtm-uprev.html
Old 11-10-2012, 12:31 PM
  #490
PhoenixBazoli
PhoenixBazoli's Avatar
enkei raijins are orgasmic lol
I love the cuscos, but your figuration appears to be track oriented
you should've gone with more adjustable sways like hotchkis
however I admire your choice, cusco sways rock, great going
Old 11-15-2012, 08:23 PM
  #491
snobes
snobes's Avatar
Any chance I could get a bit more info on this or a picture to see what u mean?
Old 11-17-2012, 12:15 PM
  #492
kacz07
kacz07's Avatar
The 1.8T's tubular exhaust manifold can be seen just behind and below the silver charge pipe on the right. Although the SGs are thermal coated, they lack heat shields and the engine bay gives off a ton of heat near the firewall as well. The built VQ hugged by the SG long tubes also cool off EXTREMELY slow, which emulates the principles of a turbo timer, no? A slow cool down? Either way, JMccarty had a turbo timer in his NA build. Food for thought.
High tech. Check out the dirt lines from the old engine bay trim. There is a good 2" of clearance, behind the engine at the windshield cowl.
Old 01-01-2013, 12:37 PM
  #493
kacz07
kacz07's Avatar
Happy New Year! Big things in 2013 for everyone!
Old 01-13-2013, 06:35 PM
  #494
Vq.turbo.DremZ
Vq.turbo.DremZ's Avatar
hows the build? still have ITB's on the build plan ?
Old 01-15-2013, 08:03 PM
  #495
kacz07
kacz07's Avatar
ITBs are really the next step. I just need to make sure it's done right. ITB kit, proper fueling, capable ECU. UpRev comes up a bit short in that respect. I would have to look at MoTeC, Haltech, or AEM's new standalone for the processing power to allow those ITBs to run smoothly.
Old 02-10-2013, 07:50 PM
  #496
graffkid732
How's everything coming along?
Old 12-07-2013, 07:26 AM
  #497
The_Assassin
The_Assassin's Avatar
Did the sg headers produce more power than those megan long tubes?
Old 12-07-2013, 11:51 AM
  #498
2004Black350z
Exhaust Whore
2004Black350z's Avatar
Yea I think 15 more hp
Old 12-07-2013, 01:56 PM
  #499
The_Assassin
Damn so I guess a proper made headers does infact produce more power than regular ebay headers
Old 12-07-2013, 04:01 PM
  #500
kacz07
kacz07's Avatar
I made 50whp more at redline, 7800.
Quick Reply: NA Build: Kacz07's 2006 SS 350z RevUP
