NA Build: Kacz07's 2006 SS 350z RevUP
Old Apr 7, 2010 | 08:41 PM
  #81
*Boose*'s Avatar
*Boose*
Can't wait for new numbers. Removing the cosworth should bring the top end back.
Old Apr 21, 2010 | 04:49 PM
  #82
kacz07's Avatar
kacz07
Current engine bay. RT Tuning engineered oversize MAF tube.
MD mani and spacer have been dropped off, but not installed.
-Looking to heatwrap the intake
-Compare IAT
-Analyze MAP and top end power of MD vs. Cosworth
-Choose which manifold has better top end powerband
-Complete NA tune
-Complete N2O tune
Old Apr 22, 2010 | 08:51 PM
  #83
whitez33350ztt's Avatar
whitez33350ztt
yeah nice car man.. i have an 03 with full bolt on and cams( bc264s) stock bottom end.. i slapped a vortech on with the stock 3.33 pulley.. with vince tuning with osiris i made 377whp at only 5800.. im going back to tune with bigger maf hopfully ill get 400+.. ur car will make power so easy with a sc.. it makes power soquick and great high end with the cams..
Old Apr 22, 2010 | 08:56 PM
  #84
03threefiftyz's Avatar
03threefiftyz
Even on my bolt-on car......the larger maf housing was a large power gainer. A little different set-up, but same principle.
Old Apr 23, 2010 | 09:53 AM
  #85
kacz07's Avatar
kacz07
I just want my car back!!! It's been sitting too long. I'm getting bored of my DD.
I have given a lot of consideration to the vortech kit, but I think I'm going to upgrade the suspension and brakes before I do ANYTHING else with the engine. I've put enough money into it for now, but when I go FI, it will be SC. I think Vince told me about your car. Great numbers, man.
Old Apr 30, 2010 | 07:14 AM
  #86
kacz07's Avatar
kacz07
Picked up a Samco intake tube. Will trim the MAF pipe before heatwrapping to fit the Samco (it is OEM fit), then I'm going to see if Vince and his crew can port stock airbox to fit. This would create a sealed intake which I think will help reduce a lot of hot air getting sucked into the motor.Might be splitting hairs, but adding a Titek air duct to the Nismo V2 will definitely help the temps, at speed.
I can only imagine what kind of heat the headers are giving off, so hopefully this will help. Wish I had those SGs with the thermal coating.
For anyone with Osiris tuning experience, although this car will be dyno tuned, can you tweak the tune through datalogging during real driving conditions on top of that dyno tune? I am just thinking that the dyno is not completely realistic for driving conditions since there is a ram effect when the car is moving.
Old Apr 30, 2010 | 09:25 AM
  #87
03threefiftyz
Do you have the tuner version? If so....yes. If not....no.
Old May 12, 2010 | 09:52 PM
  #88
kacz07's Avatar
kacz07
Hopefully getting this thing on the dyno soon for some different power results. Should be interesting.
Old May 26, 2010 | 04:37 PM
  #89
kacz07's Avatar
kacz07
Comparo to come (from filter to manifold):
Cone filter (w/ velocity stack)> oversize MAF pipe> piping (as seen in above pic)> Cosworth manifold
vs.
Cone filter (w/ velocity stack)> oversize MAF pipe> piping (as seen in above pic)> MD 5/16" spacer/Mrev2
vs.
06 airbox> GTM 3" MAF>Samco intake hose> Cosworth
vs.
06 airbox> GTM 3" MAF> Samco intake hose> MD 5/16"/Mrev2
My money is on one of the 06 airbox setups making the most power. From what I understand, the Samco piping is larger than OEM and will mate up well with the 3" MAF. Also, the Samco hose has a more gradual induction into the manifold, which I think is a big factor in SG's manifold setup, as well as pipe diameter. Aside from the larger piping, the 06 airbox combats heatsoak and takes in more colder ambient air. I will likely use a Titek CF duct to help with this as well.
I'm definitely going to have a few parts to sell once my build is completed. Anyone interested in Nismo headers, Berk HFCs, Borla TD, possibly Cosworth or MD manifold equipment?
Old May 26, 2010 | 05:28 PM
  #90
SexyRob's Avatar
SexyRob
so all tests will be done with a 3" maf??
also pm me best price on the nismo headers
Old May 26, 2010 | 05:38 PM
  #91
kacz07's Avatar
kacz07
The other MAF will be RT's engineered oversize MAF as seen in my engine bay pic, designed in the absence of Z1's MAF pipe. I had no idea until last week that GTM had one too.
PM sent.
Old May 26, 2010 | 09:50 PM
  #92
kacz07's Avatar
kacz07
Originally Posted by kacz07
The other MAF will be RT's engineered oversize MAF as seen in my engine bay pic, designed in the absence of Z1's MAF pipe. I had no idea until last week the GTM had one too.
PM sent.
Actually, I wish we could find another Samco induction hose and trim it to fit RT's MAF. Vince has a thread about MAF setups and locations for Turbo applications. I'm wondering if he's done any testing with it.
Old May 27, 2010 | 03:32 AM
  #93
SexyRob's Avatar
SexyRob
so stock is around 70mm and 3" is 78mm... the "over size" one is somewhere in between?
Old May 27, 2010 | 05:17 AM
  #94
tuko316's Avatar
tuko316
Link to samco induction hose can be purchased?
Old May 27, 2010 | 05:20 AM
  #95
tuko316's Avatar
tuko316
Also what velocity stack are you using? Did you purchase it online and what are the dimensions?
Old May 27, 2010 | 11:06 AM
  #96
kacz07's Avatar
kacz07
Yeah. I think Vince said it was like 76 or so...their MAF is also located a lot higher up on the intake tube. Vince had speculated, in that Turbo application MAF thread, that the air would have less turbulence higher up away from the filter and bends. I'm not how it would affect tuning and performance, especially on a NA, but we'll also be able to compare this, too.
Old May 27, 2010 | 11:08 AM
  #97
kacz07's Avatar
kacz07
Got mine from Oakos. Fast shipping:
http://www.oakos.com/Merchant2/merch...ory_Code=10210
Old May 27, 2010 | 03:17 PM
  #98
tuko316's Avatar
tuko316
Is that 3 inch inside diameter?
Old May 28, 2010 | 06:05 AM
  #99
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
The Samco intake hose is a nice piece - was a popular combo with our 3 inch MAF when we still offered it.
The MAF location (IMHO) is going to be inconsequential on this setup, but will be neat to see the results nevertheless. If anything, I think you may find slightly higher IAT with the MAF higher up in the pipe due to heat soak, and alot less air movement in that corner of the engine compared to up front once the hood is closed. With the hood open, I doubt it will make any power difference. I "think" because the car uses a flat panel filter in a stock airbox, that the airflow is already quite straight as it passes through the MAF. The conical filters might skew this a bit...never put one on a flow bench, would be neat to try though. I haven't found that the bend of the intake pipe (stock, Samco, and a few others) doesn't really affect things at all, since ultimately the worst turn is the one on the intake manifold itself, coupled with how the air behaves once it's actually in the plenum and being ingested into the heads. The pipe itself is a restriction, as is the filter you choose. In my last tuning session, I picked up nearly 10 whp just by letting the car run right from the throttle body. Unfortunately though, can't run this way on the street, so I went back to running it as it was (3 inch silcione pipe, 3 inch hard pipe, and HKS filter). But again, will be neat to see how this affects your engine. Hopefully you find what you're after
Old May 28, 2010 | 09:17 AM
  #100
kacz07's Avatar
kacz07
-I agree with you on the manifold elbow being a huge restriction
-I have been talking with Vince about some fab. work on the manifold and TB w the intake of choice
-Good point with the MAF location
I am really just trying to wrap up the first stage of the intake/manifold to get my car on the road. It's been too long! I want to break this bad boy in. Still have a few tricks up the sleeve, but I think the community will learn a lot from the comparisons. I guess I'm footing the bill, though. I think what the build really needs is a single turbo from Boosted Performance!
